Linguaggio Onebox
Just testing here… I’m sure there is documentation on this somewhere, just curious about the language switch.
Added link here:
Link added on my forum:
Ok, looks ok here. Maybe I explain this topic…
A user posted some FB links on my forum but they popped up as German versions. Getting a “login request” as the link is bad enough but getting it in the wrong language is worse.
Don’t think I’ve seen this problem happen before. Haven’t updated Discourse for months either. Bad flu so will dig into this later…
Please use https://try.discourse.org for testing.
Yeah, didn’t even have to post to see the difference in the preview to the right. Searching for “url link” stuff didn’t show me an easy why, so just wrote an entire post in the same go and let it fly.
So would the reason be that this is some Onebox stuff and Facebook has a messed up “OpenGraph” or “oEmbed” tag? Or is this something the actual site you visit has to do and Facebook just pops the login back anyway? Basically I’m just asking if this could be an Onebox bug where the algorithm for some reason uses the incorrect language?
Ok, flu, slow brain, should stop posting for tonight, does not improve things :smiley: , sorry.
Is your server located in Germany?
Bene, si trova da qualche parte su DigitalOcean e per la maggior parte del tempo è a Francoforte, quindi sì (139.59.213.172). Per qualche motivo, una ricerca ora mostra l’Australia :).
Ho controllato la pagina Facebook che ha oEmbed, ma comunque, perché due pagine su tante finirebbero in tedesco?
www.facebook.com/agrasdistillery
Mi piace quando le cose sono deterministiche :D.
Ciao!
C’è qualche soluzione alternativa per evitarlo? Vorrei che solo l’inglese apparisse nei onebox di Facebook invece del finlandese…
Il mio server è in Germania, i miei forum sono in spagnolo e i collegamenti mi appaiono in quello che penso sia russo :thinking:
