Oneboxing xkcd?
The discussion revolves around adding oneboxing support for xkcd.com in Discourse. thiagoarrais initiated the conversation, asking if there’s interest in implementing it and opened a PR #328 to explore the idea. Falco initially suggested xkcd supports OpenGraph tags — later corrected to note Facebook Debug generates them dynamically — and encouraged whitelisting the domain. KevinWorkman questioned the approach, pointing out xkcd lacks native OpenGraph tags and recommended studying third-party oEmbed providers or the xkcd API. He also expressed concern about submitting a PR before functionality is confirmed, and later suggested this feature might better belong in a plugin rather than core, citing stability and scope concerns. thiagoarrais clarified the PR was meant as a discussion placeholder and later updated it with a working version. Falco countered that xkcd’s popularity justifies a custom onebox, similar to other major sites. Ultimately, codinghorror confirmed xkcd oneboxing already works, thanks to @zogstrip — implying the effort was unnecessary, though appreciated.
Would there be interest in oneboxing xkcd? I don’t know if XKCD supports oEmbed or whatever, but I’m willing to try a PR if there is interest.
2 Mi Piace
XKCD supports OpenGraph tags already. Just whitelist it.
1 Mi Piace
Simply adding the domain to the whitelist didn’t work. Maybe I’m doing something wrong here.
I’ve opened PR #328 on Github with what I have so far. I’ll take a better look at this later. Should I interact with the team here or in the github PR?
1 Mi Piace
Googling “xkcd oembed” returns a ton of results, most of which appear to be third party oembed providers. You might start by researching how those are put together, but I would guess they’re using the xkcd api.
Looking at the source of xkcd, I don’t see any OpenGraph tags though.
I also don’t understand why you’ve already opened a pull request, especially if you know it doesn’t work. Maybe I’m just misunderstanding how pull requests are meant to be used though.
1 Mi Piace
I’ll take a look at those thirdy party providers, @KevinWorman. Thanks.
I didn’t see any OpenGraph tags either. But I’m a both a onebox newbie and an opengraph newbie. Maybe I’m looking at the worng place.
At this point, I’ve opened the PR as a placeholder for the discussion only. If the team prefers, I can close and re-open it only when fully ready.
I don’t think that @Falco meant you should change the whitelist for everybody. I think he meant you should go to your admin console, then Settings, then Onebox, then add xkcd to your onebox domains whitelist.
But given that I don’t see any OpenGraph tags on xkcd, I’m not sure how this will help. I might be missing something though.
3 Mi Piace
I’ve put together a first version and updated the Pull Request. I’m still having trouble with the specs, but I’ll take a look at that next.
3 Mi Piace
Nice. Sorry about earlier when I said xkcd had og tags. I used Facebook Debug to test, and they create the og tags from content when needed.
6 Mi Piace
I’m done with #328. Let me know if I need to post the PR somewhere else or if you need anything else.
3 Mi Piace
This feels like it would be more at home in a plugin, doesn’t it? If I don’t care about oneboxing xkcd, why would I want to potentially break my Discourse because of it? What if xkcd goes down? Or changes how its API is designed?
It’s cool that you did this, but I’m just not sure it belongs in core Discourse so a pull request feels a little premature. But again, maybe I’m completely wrong!
2 Mi Piace
Actually Onebox is an independent library.
I, for one, think that xkcd is a big enough website to justify a custom one boxer, like we do with another big sites.
6 Mi Piace
This works now and has for a while thanks to @zogstrip :fr:
3 Mi Piace
