מפרטי OptimizedImage נכשלים עם Ruby 3.0.2
I’m working on supporting Ruby 3 and got this spec failure.
Steps to reproduce
  1. Run Ruby 3.0.2
$ cd discourse
$ bundle exec rspec spec/models/optimized_image_spec.rb:10
Expected result
It should finish successfully as follows
1 example, 0 failures
Actual result
It always get failure as follows.
Run options: include {:locations=>{"./spec/models/optimized_image_spec.rb"=>[10]}}
Randomized with seed 44957
F
Failures:
  1) OptimizedImage.crop should produce cropped images (requires ImageMagick 7)
     Failure/Error: expect(cropped_size).to be < 120
       expected: < 120
            got:   9476
     # ./spec/models/optimized_image_spec.rb:27:in `block (3 levels) in <top (required)>'
     # ./spec/rails_helper.rb:279:in `block (2 levels) in <top (required)>'
Finished in 0.22966 seconds (files took 2.89 seconds to load)
1 example, 1 failure
Failed examples:
rspec ./spec/models/optimized_image_spec.rb:10 # OptimizedImage.crop should produce cropped images (requires ImageMagick 7)
Diag info
This failure is related to this line.
When it runs with Ruby 2.7.4 it works but with Ruby 3.0.2 it raises “can’t convert ImageOptim::Timer into Float (TypeError)”. Here are the minimum steps to reproduce.
$ more foo.rb
gem 'image_optim'
require 'image_optim'
timeout = ImageOptim::Timer.new(15.0)
args = [{"PATH"=>
   "/usr/bin"},
   "date"
pid = Process.spawn(*args)
waiter = Process.detach(pid)
waiter.join(timeout)
  • With Ruby 3.0.2, it shows “can’t convert ImageOptim::Timer into Float (TypeError)”
$ ruby -v
ruby 3.0.2p107 (2021-07-07 revision 0db68f0233) [x86_64-linux]
$ ruby foo.rb
foo.rb:14:in `join': can't convert ImageOptim::Timer into Float (TypeError)
	from foo.rb:14:in `<main>'
Fri Oct  1 12:42:51 PM JST 2021
  • With Ruby 2.7.4 it works with no exception.
$ ruby -v
ruby 2.7.4p191 (2021-07-07 revision a21a3b7d23) [x86_64-linux]
$ ruby foo.rb
Fri Oct  1 12:44:00 PM JST 2021
Looks like there is a trivial fix there … just add a .to_f
if waiter.join(timeout.to_f)
Can you send a PR through?
Thanks for the suggestion. Sure. Will open a pull request to GitHub - toy/image_optim: Optimize images using multiple utilities · GitHub .
Opened Fix: TypeError: can't convert ImageOptim::Timer into Float by yahonda · Pull Request #194 · toy/image_optim · GitHub
