`uploads:regenerate_missing_optimized` échoue à générer les images optimisées manquantes
rake uploads:missing a détecté 225 images optimisées manquantes, toutes nommées *10x10.png
La tentative de régénération des fichiers manquants via rake uploads:regenerate_missing_optimized génère 225 erreurs de type : ‘convert: improper image header’ et ‘convert: no images defined’ dans le journal des erreurs. Version 2.4.0.beta10 (c5e3faac00)
hostname	discourse-app
process_id	9853
application_version	6455c6ee872109fc3da9a2b45f6b7466bb96c123
location	/var/www/discourse/public/uploads/default/optimized/2X/9/97f2e2dfda850e56bf8ef65cfc7ee2c885285b4b_2_10x10.png
error_message	lib/discourse.rb:57:in `exec': convert: improper image header `/var/www/discourse/public/uploads/default/original/2X/9/97f2e2dfda850e56bf8ef65cfc7ee2c885285b4b.jpg' @ error/png.c/ReadPNGImage/4294. convert: no images defined `png:/var/www/discourse/public/uploads/default/optimized/2X/9/97f2e2dfda850e56bf8ef65cfc7ee2c885285b4b_2_10x10.png' @ error/convert.c/ConvertImageCommand/3273.
time	7:22 am
Retrace de la pile dans les journaux :
lib/discourse.rb:644:in `block in warn'
lib/discourse.rb:638:in `each'
lib/discourse.rb:638:in `warn'
/var/www/discourse/app/models/optimized_image.rb:350:in `rescue in convert_with'
/var/www/discourse/app/models/optimized_image.rb:332:in `convert_with'
/var/www/discourse/app/models/optimized_image.rb:327:in `optimize'
/var/www/discourse/app/models/optimized_image.rb:307:in `resize'
/var/www/discourse/lib/tasks/uploads.rake:467:in `block (2 levels) in regenerate_missing_optimized'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/relation/batches.rb:70:in `block (2 levels) in find_each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/relation/batches.rb:70:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/relation/batches.rb:70:in `block in find_each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/relation/batches.rb:136:in `block in find_in_batches'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/relation/batches.rb:238:in `block in in_batches'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/relation/batches.rb:222:in `loop'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/relation/batches.rb:222:in `in_batches'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/relation/batches.rb:135:in `find_in_batches'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/relation/batches.rb:69:in `find_each'
/var/www/discourse/lib/tasks/uploads.rake:436:in `block in regenerate_missing_optimized'
/var/www/discourse/lib/tasks/uploads.rake:435:in `each'
/var/www/discourse/lib/tasks/uploads.rake:435:in `regenerate_missing_optimized'
/var/www/discourse/lib/tasks/uploads.rake:406:in `block (2 levels) in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.0.7/lib/rails_multisite/connection_management.rb:63:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.0.7/lib/rails_multisite/connection_management.rb:73:in `each_connection'
/var/www/discourse/lib/tasks/uploads.rake:406:in `block in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:188:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:160:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:125:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:110:in `top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:83:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:186:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:80:in `run'
bin/rake:13:in `<top (required)>'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli/exec.rb:63:in `load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli/exec.rb:63:in `kernel_load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli/exec.rb:28:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli.rb:476:in `exec'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/vendor/thor/lib/thor.rb:399:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli.rb:30:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/vendor/thor/lib/thor/base.rb:476:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli.rb:24:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/exe/bundle:46:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/friendly_errors.rb:123:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/exe/bundle:34:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Voici les fichiers présents sur le disque (pour une telle image) — remarquez le PNG 10x10 de 0 Ko :
Optimisé (shared/standalone/uploads/default/optimized/2X/9/) :
97f2e2dfda850e56bf8ef65cfc7ee2c885285b4b_2_690x517.jpeg 172 KB
97f2e2dfda850e56bf8ef65cfc7ee2c885285b4b_2_667x500.jpeg 163 KB
97f2e2dfda850e56bf8ef65cfc7ee2c885285b4b_2_10x10.png      0 KB
Original (shared/standalone/uploads/default/original/2X/9/) :
97f2e2dfda850e56bf8ef65cfc7ee2c885285b4b.jpg   94 KB
OK, alors quel est le problème ? Ignorez simplement ces images malformées et continuez.
(Ou supprimez-les des publications où elles se trouvent probablement ?)
Ces images ne sont pas corrompues ; elles s’affichent correctement dans le message.
Ce qui est corrompu (ou plutôt non généré), c’est l’image optimisée pour le « défilement rapide », qui échoue à être générée à partir de l’original.
Son absence peut être détectée lors d’un défilement rapide dans le message.
J’ai modifié le titre pour plus de clarté.
Salut, @md-misko
As-tu réussi à résoudre ton problème ?
Je rencontre moi aussi des problèmes similaires.
Depuis, j’ai migré vers S3 et je ne peux plus exécuter rake uploads:missing contre S3, mais j’ai vérifié le fichier mentionné ci-dessus et il a maintenant une taille non nulle sur S3. Il semble donc que cela soit résolu.
Êtes-vous sur la dernière version ?
Ah ! Je ne savais pas que cette commande n’est pas destinée aux buckets S3.
Oui. Je mets toujours à jour vers la dernière version. Au maximum, je peux être en retard de 2 à 3 jours parfois.
En tout cas, si vous le savez, quelle est la meilleure commande pour trouver les images téléchargées manquantes, ou quelle est la commande pour mapper les URL des posts vers les bonnes images dans le bon bac (si les chemins ont été corrompus pour une raison quelconque) ?
Cela semble sans rapport avec le problème décrit dans le message original. Peut-être ouvrir un nouveau sujet dans Support et décrire exactement quel est votre problème.
