Ordered lists with non-number markers discussion revolves around the limitation of list formatting in Discourse. djr013 requests to whitelist the “type” attribute of <ol> and “reversed” and “value” for <ol> and <li> respectively, to facilitate the use of semantically-meaningful list markers, particularly in legal or technical documents.
djr013 emphasizes the need for this feature, citing difficulties in quoting official documents with non-number markers. Falco proposes a workaround using a wrapper and CSS, but djr013 argues that this solution is only suitable for decorative purposes, not semantically-meaningful situations.
FroggyC and JammyDodger discuss the implementation of HTML attributes, including <ol type> and <ol reversed>. However, FroggyC and FroggyC express concerns about the limitations of using HTML within Markdown lists.
Ultimately, JammyDodger suggests starting a Development topic for help with tweaking existing solutions. Despite codinghorror stating there are no plans for implementing the requested feature, the discussion highlights the need for more flexible list formatting options in Discourse.
Request: Add “type” attribute of <ol> to whitelist. Suggestion to do the same with “reversed” for <ol>, and “value” for <li>, for similar but less common reasons.
Purpose: These attributes are intended for use where the marker of ordered list items itself conveys meaning to the content of the list. Typically this is the case when list items are intended to be referred to via this marker. This is in contrast to CSS list-style-type which is intended where the choice of marker carries no significant purpose. (Though I did see it recommended for forum-wide localization, which is pretty great!)
Background: While attempting to quote an official reference document, I discovered an apparent limitation in list formatting which prevents doing so accurately. Quite often, list markers are purely stylistic. However, they are occasionally used to facilitate reference in list-heavy documents. For example, in official and legal documents, a list item (or sub-item) might be referred to by list marker: “Official Document Article I, section 1(a)(i)”
I’m uncertain of whether a standard method is available in BBCode, to the extent anything is standard in BBCode. I was unable to find anything more advanced than starting at an arbitrary digit. BBCode list tags don’t appear used by Discourse, anyway.
With HTML and HTML+style, neither produce the correct result:
Though I do notice that introducing these will leave the HTML-to-markdown converter unaware of these attributes. But as demonstrated above, markdown-it currently can’t handle markdown syntax representing these anyway. For that, it may be desirable to go a step further and implement list types in CommonMark…
The lack of this makes it very difficult to quote official documents, legal documents, software licenses, or anything else which use non-number markers for document references.
That’s a good solution if the goal is arbitrary list decorations, but the HTML type attribute is specifically meant for semantically-meaningful situations where the difference between list markers are more than decorative. From <ol> HTML ordered list element - HTML | MDN
Unless the type of the list number matters (like legal or technical documents where items are referenced by their number/letter), use the CSS list-style-type property instead.
It’s a common enough need that although the HTML attribute was deprecated in HTML 4.01 (with justification of it being purely stylistic), it was subsequently re-introduced in HTML5 for the specific purpose of encoding reference lists as described by MDN.
I tried using this solution and it works, correcting the CSS to the following (the first line was missing an ol {):
.cooked div[data-wrap="letterlist"] ol {
list-style: upper-alpha;
However I can’t get it to show in the editor preview window, which is going to be a bit of an issue for most of my users. I’ve tried inspecting with the web browser, and it seems the custom CSS is not loaded or applied to the preview (I’m not a professional at this, so I might be wrong).
Any way you can think of to solve this problem, @Falco?
I know. As I said, I don’t find that acceptable to propose to my users—it completely changes the markup just because you want a slightly different list.
