There’s an option in Admin UI to override new user preferences.
Is there a way of overriding existing user preferences?
I’d like to set all users’ settings to these:
And also to add a category (Announcements) to their Watched category list.
Yes, search Admin > Settings area for the word ‘default’
Note: This only applies to new user signups, current users will not have their preferences changed.
As I say in the original topic:
Edit: I revised the title of the topic to make my question more clear.
Console App. You can Run a command in the Rails Console, @zogstrip has provided a few examples in other topics on how to do it.
Here is one such instance
https://meta.discourse.org/t/category-watched-tracked-by-default/34680/7?u=cpradio
The ability to use the UI to push down a setting to all current users, one time, would make implementing new features So Much Better.
from
to
https://meta.discourse.org/t/how-to-control-previous-replies-in-emails/39834/9
An option in the admin UI to “apply to all” could help all existing Discourse communities, especially ones which are Hosted, where admins don’t have access to the rails console at all.
Though I can see where such a feature could be helpful, IMHO this is dangerous territory.
I have no problems with default values for new users.
BUT - if I have set a preference option and it changed
Good points @Mittineague but where I need this is in cases where:
In all of these cases, the need here is to be able to Fix Our Forum for our users. If I expected to have to use this feature regularly on the same setting, I’d be asking for a way to lock the preference in place.
If I were starting a discourse now, I may not need this as much, at least not until I added a new category, or the next new feature in discourse was added) As it stands, the 4 Discourse I manage all had many users were created before we (as discourse admins) even had a chance to set the desired defaults.
