تجاوز طريقة في وحدة تحكم
Hi All,
I am attempting in overriding the behaviour of a an action controller, to be precise, the TopicsController#latest, I want to add a custom field to it as part of the response.
And in order to do that I have created a plugin, with:
after_initialize do
  class TopicsController
    def latest
      render json: MultiJson.dump( "test": "ashdjagds" );
But it does not work when I make a request, I mean it does not return the {“test”: “ashdjagds” } part,
Any suggestion ?
You should check the class first. We don’t have latest method in TopicsController. Instead you need to override the ListController.
4 إعجابات
