I know I had previously asked for aggregation on the annual range, but the recent updates render the visualization illegible:
Well-meaning suggestions:
- A weekly (rather than monthly) aggregation would be comfortable and preferable at this scale
- Regardless, the bars need to be configured with enough width to be legible and hoverable
Lastly, the recent addition of vertical gridlines is a real negative IMO. It’s just visual clutter that is distracting and makes comparing heights across different bars much more difficult to do at a glance. Having a vertical gridline corresponding to some empty tick in between bars tells the viewer absolutely nothing. [*] I would suggest reverting this change, or offering a configuration for a simpler style (or if this can be overridden via CSS theme, any pointers are appreciated).
[*]: properly this would be a categorical range with discrete weeks or months as the factors, not a datetime range at all.
