What would you like done?
i want someone to installed and setup discourse on my cloud hosting LINODE
When do you need it done?
i need this to get done soon
What is your budget, in $ USD that you can offer for this task?
10-20$
please contact me
A user Famebo_Social requested a paid Discourse installation on Linode with a tight budget of $10–20. pfaffman shared that their professional installation costs $99 and noted that Linode presents slightly more complexity than Digital Ocean regarding swap partitions. Although Famebo_Social considered switching providers due to budget constraints, ljpp clarified that Linode issues can be resolved in approximately 30 seconds via the dashboard, though this requires manual intervention.
pfaffman acknowledged the difficulty for non-technical users who might not know where to look, admitting they use APIs for efficiency. Despite this, pfaffman advised Famebo_Social to attempt the setup themselves given the low budget, encouraging them to seek help in the installation category if needed. The conversation shifted to automation, with pfaffman revealing their long-term plan to build a web interface for basic Discourse administration tasks, humorously contrasting their preference for terminal commands with their clients’ needs.
10-20$
please contact me
Just for a frame of reference is my $99 install.
It looks like it’s a bit more trouble on Linode than digital ocean
thanks for the advice i will go with Digital Ocen then , but 99$ is way out of my budget for discourse installation
While Digital Ocean is very good, there really is not any trouble with Linode either. They create a swap partition by default, which is not ideal for ./discourse-setup , but it can be fixed via their dashboard literally in 30 seconds.
Perhaps “more trouble for me than DIgital Ocean” would have been more accurate. But solving that problem in 30 seconds assumes that you know to fix it and can find the place to do it. It wasn’t immediately obvious to me when I last checked it out. That said, checking out Linode again is on my TODO list. Perhaps I’ll add a Linode install to my products sometime in the future; I don’t see in 5 minutes how swap is configured via their API, however.
Yeah, I do not use APIs. I am a casual user.
Hey, @Famebo_Social. It might take you more than 30 seconds to disable the swap so that ./discourse-setup can work, but at your budget, it might be worth some of your time to check it out. You can post in #installation if you get stuck. Lots of people are likely interested in how to do it.
I do use APIs. I’m profoundly lazy, in a very perverse way. I’ve spent hours tweaking my install script. I’m pretty sure that if I’d just done all of those installs via the mailgun and Digital Ocean interfaces, I’d have spent less time. ![]()
Now you got me interested. Have you shared your scripting magic here? ![]()
Not at this point. Of course, it’d take much longer to make my scripts work than to install Discourse 100 times. I don’t know who’d want them except someone who wanted to offer a $98 install. ![]()
My longer-term plan is to provide a web interface that will install Discourse and do basic administration tasks. For example, one might log in to my portal and click a “rebuild” button to do a ./launcher rebuild app on their Discourse. (I’d rather scratch my eyes out than use a web browser when it’s so much easier to type into a “black box,” as my partner calls terminal windows, but I’m different from my clients.)
