I want to allow my users to link their Xbox gamertags and information, but it seems that the plugin only retrieves data from their Microsoft profile (not their Xbox Live profile).
Are you aware of documentation that shows its possible to do what you ask?
I suspect that you’re budget is off by a factor of ten. It is a $50 to $100 job to see if it’s even possible.
There could be some way that’s easier than i can imagine, but you’ll need to do the work to figure out how to solve the problem first.
One solution that might fit your budget would be to have users use keybase to prove their connection to both your forum and their Xbox profile and then link to that somehow.Darn. I don’t see an easy way to do that either.
That’s a lot more than just “authentication” because all Microsoft services (including Xbox) just uses your Microsoft account. So you’re looking for something that specifically pulls up that information, which you can do but I doubt as a login authenticator.
