Je ne suis pas sûr qu’il s’agisse d’un bug ou non.
Dans le deuxième cas, est-il possible de forcer le lien à apparaître dans l’éditeur au-dessus (ou en dessous) du formulaire ?
Oh I see. Not sure what do you think @neil?
There’s no way to force it. But if you choose to allow links in a category with templates, then I guess we should do something with the links. @Trash Do you think they should go below or above the template? I’m against adding yet-another setting for it.
Well, maybe below the template is better, so the form is always the first thing you’ll see as a user that open the topic (with link as title or not) to read it.
I made this change today. Links will get oneboxed below the template.
