When pasting from a Google Doc into the Discourse composer, formatting such as bold and text alignment (left, center, right) is lost. Sören_Geier has reported this issue and provided a Google Doc example to demonstrate the problem.
According to dax, this is not a bug. The issue arises because the pasted content does not contain HTML syntax, so it is converted to Markdown. However, Markdown does not support centering text or images. To achieve this, HTML syntax is required, such as <div align=center>Centered text</div>.
Additionally, dax pointed out that the use of a dotted line immediately under “Strong Text” in the original post was converted to an H2 heading due to Markdown syntax. To avoid this, a blank space should be added between the text and the dotted line.
To address these issues, dax suggested using the CommonMark tutorial to learn Markdown syntax and exploring theme components like MD Composer extras, which add extra buttons to the composer, including those for alignment.
Hi there,
when pasting simple Google docs into the composer we see formatting getting lost.
Bold and alignment (left, center, right) get lost completely. Headlines get properly converted when marked as such in the original Google document.
The text below is pasted from a Google doc and loses bold as well as centered text information.
In publishing and graphic design, Lorem ipsum is a placeholder text commonly used to demonstrate the visual form of a document or a typeface without relying on meaningful content. Lorem ipsum may be used as a placeholder before the final copy is available.
Strong text
Other observations:
Pasting from a Word document converts strongs but also looses alignment information.
On our managed instance I don’t see the strong text to be wrapped into a B or STRONG tag, so I cant style it accordingly.
Document does not contain an HTML syntax then it will be converted to Markdown and there’s no Markdown syntax to center text, images, titles etc. To center texts you need to use HTML, as example:
will become
Centered text
This is not a bug and is happening because you added a dotted line immediately under “Strong Text”
