Pdf-verslag van peilingen toont 0 stemmen
The discussion revolves around the issue of generating a PDF record of a poll from a Discourse topic, where the printed version incorrectly shows “0 voters” despite the poll having actual votes (6 for, 0 against). nhoj highlights the problem when using Ctrl-P in Firefox and Brave, noting that the vote count is rendered via JavaScript and thus absent in the print-friendly, JS-free version. Falco explains that displaying vote numbers in HTML would require extensive renaming, making it impractical, and suggests taking a screenshot as a workaround. nhoj criticizes hiding the vote numbers as insufficient, emphasizing that poll results are often the key information in a topic. wolftune calls this a bug, arguing that if votes can’t be displayed, the system should not show “0 votes” at all. The discussion concludes with codinghorror suggesting a quick CSS fix, and awesomerobot confirming that a fix has been implemented to hide the incorrect vote count in print and crawler views.
I (unfortunately) need to make a permanent record of a poll for regulatory purposes. How best to preserve a topic/post/poll as a permanent record
When I press Ctrl-P to create a pdf of the topic (in Firefox & Brave) the generated pdf shows:
  • For
  • Against
0 voters
When the pdf was generated, the (still open) poll actually had 6 voters on screen (6xFor, 0xAgainst).
Our printer version of the page is JS free, and looks like the votes are attributed via JS.
Putting this information in HTML would require a rename on every vote, making it prohibitively expensive.
Your best best is taking a screenshot of said poll. And for our print page, hiding vote numbers is the easiest solution…
Thanks for replying so quickly!
My workaround for now is to print to pdf and then edit/correct the pdf.
Hiding the error seems like a fairly weak step in the right direction. When I have to print a page, it seems fairly important to have (all) of the information on the page included - particularly the result of a poll, which is likely the crucial point of the topic!?
Just ran into this. Seems a clear bug. Would be certainly an improvement to eliminate the “0 votes” part from HTML, that shouldn’t even exist. If noJS can’t show votes, it should never show “0 votes”. It shouldn’t say anything about votes unless it can show them correctly.
The full fix would probably involve a “print” function added to Discourse that actually then outputs the appropriate HTML when someone wants to make a print version of something that includes a poll.
Can we do a quick fix in the print CSS for polls @awesomerobot ?
Yeah this hides it from print:
https://github.com/discourse/discourse/pull/15901
and from crawler view:
https://github.com/discourse/discourse/pull/15903
