Sorry for the belated response. I’ve just enabled the setting and given it a run-through on my test site to check and I’m also seeing similar behaviour, but only if I don’t refresh the page before trying to perform the permanent delete.
My step-by-step:
Soft delete an existing post
Open post wrench and click ‘Permanently delete’
‘Are you sure you permanently want to delete this post? You will not be able to recover it.’ confirm modal appears
Click on ‘Yes’
Modal closes, but no response. Post remains soft-deleted
However, if I add a page refresh it works as intended:
Refresh page
Reveal soft-deleted post using ‘View hidden reply’
Click on ‘Yes’
And the post is permanently deleted (as long as I’ve waited 5 minutes, or used a second test user with admin privileges)
Does this sound familiar, or could I try something else to replicate what you’re seeing?
I see the issue you are talking about, all of this is lining up with current functionality that I’m seeing too.
A few things to add to the observations:
If I refresh on a soft deleted page after 5 minutes has passed, and I permanently delete the post, the topic is still not deleted. I get the modal that you’re seeing and I press OK. For posts other than the original post, it works.
However, if I go to /latest?status=deleted it still comes up in the list of topics. The topics show Replies -1, and if I click on these topics I then see “ error something went wrong” page.
I did receive a 500 error at one point, this looks like perhaps the topic was still deleting or something and perhaps I tried deleting it while it was in progress:
Looking at the error log this is what I see:
Excellent. I think that’s just the info I needed for a repro.
I’ve tried again, but with a topic that consists of only the OP:
Create topic (with no replies)
Soft-delete topic (and wait 5 minutes)
Open post wrench and select ‘Permanently delete’
Confirm
‘Error. Something went wrong’
Topic still appears in ?status=deleted, but gives an ‘Error. Something went wrong’ screen when accessing and gives this message in the console:
TypeError: p is undefined
setupController topic-from-params.js:68
setup Ember
s router_js.js:1514
routeEnteredOrUpdated router_js.js:1524
setupContexts router_js.js:1470
finalizeTransition router_js.js:1378
promise router_js.js:1321
b rsvp.js:435
g rsvp.js:421
invoke queue.ts:203
flush queue.ts:98
flush deferred-action-queues.ts:75
_end index.ts:616
end index.ts:298
_run index.ts:667
run index.ts:339
d Ember
success ajax.js:101
jQuery 6
y ajax.js:150
E rsvp.js:460
E rsvp.js:916
f ajax.js:163
loadTopicView topic.js:24
getAndRemove preload-store.js:28
E rsvp.js:460
E rsvp.js:916
getAndRemove preload-store.js:27
refresh post-stream.js:264
model topic-from-params.js:25
deserialize Ember
getModel router_js.js:775
resolve router_js.js:616
b rsvp.js:435
g rsvp.js:421
invoke queue.ts:203
flush queue.ts:98
_end index.ts:616
_boundAutorunEnd index.ts:257
promise callback*n/< platform.ts:28
flush Ember
_scheduleAutorun index.ts:803
_ensureInstance index.ts:791
schedule index.ts:384
<anonymous> Ember
v rsvp.js:492
resolve router_js.js:934
y router_js.js:249
getTransitionByIntent router_js.js:1305
transitionByIntent router_js.js:1247
doTransition router_js.js:1366
transitionTo router_js.js:1776
Ember 2
handleURL url.js:366
routeTo url.js:211
w topic-list-item.js:31
click topic-list-item.js:187
Ember 5
application.js:83
