phpBB3 Import Failing with Zeitwerk::NameError on Current Discourse Version
I’m attempting to import a phpBB3 forum following the official migration guide, but the import script fails immediately with a Zeitwerk::NameError.
Environment
  • Discourse version: v2026.2.0-latest-324 (also tried stable/esr branch)
  • Installation: Docker-based import container
  • Previously: Successfully imported the same phpBB forum in early January 2026 without issues
The Error
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.3/lib/zeitwerk/loader/callbacks.rb:31:in 'Zeitwerk::Loader::Callbacks#on_file_autoloaded': expected file /var/www/discourse/lib/freedom_patches/safe_migrations.rb to define constant FreedomPatches::SafeMigrations, but didn't (Zeitwerk::NameError)
discourse@vps116136-import-from-app:/var/www/discourse/script/import_scripts$ bundle exec ruby phpbb3.rb /shared/import/settings.yml
      raise Zeitwerk::NameError.new(msg, cref.cname)
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.3/lib/zeitwerk/core_ext/kernel.rb:27:in 'Kernel#require'
        from /var/www/discourse/config/initializers/002-freedom_patches.rb:11:in 'block (2 levels) in <main>'
        from /var/www/discourse/config/initializers/002-freedom_patches.rb:9:in 'Array#each'
        from /var/www/discourse/config/initializers/002-freedom_patches.rb:9:in 'block in <main>'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/callbacks.rb:406:in 'BasicObject#instance_exec'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/callbacks.rb:406:in 'block in ActiveSupport::Callbacks::CallTemplate::InstanceExec0#make_lambda'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/callbacks.rb:178:in 'block in ActiveSupport::Callbacks::Filters::Before#call'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/callbacks.rb:668:in 'block (2 levels) in ActiveSupport::Callbacks::CallbackChain#default_terminator'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/callbacks.rb:667:in 'Kernel#catch'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/callbacks.rb:667:in 'block in ActiveSupport::Callbacks::CallbackChain#default_terminator'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/callbacks.rb:179:in 'ActiveSupport::Callbacks::Filters::Before#call'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/callbacks.rb:559:in 'block in ActiveSupport::Callbacks::CallbackSequence#invoke_before'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/callbacks.rb:559:in 'Array#each'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/callbacks.rb:559:in 'ActiveSupport::Callbacks::CallbackSequence#invoke_before'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/callbacks.rb:108:in 'ActiveSupport::Callbacks#run_callbacks'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/reloader.rb:96:in 'ActiveSupport::Reloader.prepare!'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/application/finisher.rb:73:in 'block in <module:Finisher>'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/initializable.rb:32:in 'BasicObject#instance_exec'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/initializable.rb:32:in 'Rails::Initializable::Initializer#run'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/initializable.rb:61:in 'block in Rails::Initializable#run_initializers'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:231:in 'block in TSort.tsort_each'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:353:in 'block (2 levels) in TSort.each_strongly_connected_component'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:434:in 'TSort.each_strongly_connected_component_from'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:352:in 'block in TSort.each_strongly_connected_component'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:350:in 'Rails::Initializable::Collection#each'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:350:in 'Method#call'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:350:in 'TSort.each_strongly_connected_component'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:229:in 'TSort.tsort_each'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:208:in 'TSort#tsort_each'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/initializable.rb:60:in 'Rails::Initializable#run_initializers'
        from /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/application.rb:444:in 'Rails::Application#initialize!'
        from /var/www/discourse/config/environment.rb:7:in '<top (required)>'
        from /var/www/discourse/script/import_scripts/base.rb:16:in 'Kernel#require_relative'
        from /var/www/discourse/script/import_scripts/base.rb:16:in '<top (required)>'
        from /var/www/discourse/script/import_scripts/phpbb3/support/settings.rb:5:in 'Kernel#require_relative'
        from /var/www/discourse/script/import_scripts/phpbb3/support/settings.rb:5:in '<top (required)>'
        from phpbb3.rb:17:in 'Kernel#require_relative'
        from phpbb3.rb:17:in '<module:PhpBB3>'
        from phpbb3.rb:16:in '<module:ImportScripts>'
        from phpbb3.rb:15:in '<main>'
What I’ve Tried
  1. Different Discourse versions: Tested with latest, stable, and esr branches - all fail with the same error
  2. Different Rails environments: Tried RAILS_ENV=production and RAILS_ENV=development
  3. Fresh container builds: Destroyed and rebuilt import container multiple times
  4. Bundle install: Updated dependencies with bundle install
Root Cause Analysis
The file /var/www/discourse/lib/freedom_patches/safe_migrations.rb only defines the SafeMigrations constant when RAILS_ENV != "production":
if ENV["RAILS_ENV"] != "production"
  require_dependency "migration/safe_migrate"
  Migration::SafeMigrate.patch_active_record!
However, the initializer /var/www/discourse/config/initializers/002-freedom_patches.rb tries to require this file unconditionally, causing the Zeitwerk error in production mode.
Questions
  1. Has anyone else encountered this issue with recent Discourse versions?
  2. Is there a known workaround or fix?
  3. What Discourse version is currently recommended for phpBB imports?
The fact that this worked in January but fails now suggests a recent breaking change in Discourse core affecting imports. Any guidance would be greatly appreciated!
