אנא אל תקשרו קישורים כפולים אם מדביקים קישור על גבי קישור ב-markdown
Continuing the discussion from Idea: Paste links in the editor:
I just ran into this and it was driving me crazy. I had a link in a post that went to the wrong place:
[The Right Place](https://example.org/the-wrong-url)
and I noticed that and copied the right URL, https://example.org/the-right-place, and then pasted it, and got this confusing result:
[The Right Place]([https://example.org/the-wrong-url](https://example.org/the-right-place))
Huh. I thought. Let me try that again. Is there some sort of new Firefox/Wayland past bug? So I selected the part in between the ()s again, and…
[The Right Place]([[https://example.org/the-wrong-url](https://example.org/the-right-place)](https://example.org/the-right-place))
OMG SO CONFUSED!!!1
Then I happened to remember I’d happened to scroll by the topic linked above the other day. I’m glad I had, because I guarantee you I would have been perplexed for a much longer time than one would hope from a person who is supposed to be smart.
Can this code please be adjusted to not do this at least to text that is a markdown link, but actually probably never to any URL ever, because
doesn’t seem like something anyone should be encouraged to do — let alone possible tricked into doing by the software trying to be helpful at the wrong time.
8 לייקים
What exactly did you highlight when you pasted the second time? If the markdown is already set to [The Right Place](https://example.org/the-wrong-url), I highlight https://example.org/the-wrong-url and paste https://example.org/the-right-place, it just replaces the first URL with the second.
Also, pasting a standalone URL on top of another URL just replaces it. It doesn’t do this as far as I can see.
Maybe these issues have already been fixed?
לייק 1
I just checked, and while it doesn’t happen here, it does happen on the Fedora sites and on https://discuss.python.org/. Perhaps there’s a fix in testing here that hasn’t gone out to hosted sites generally?
לייק 1
I think there’s generally a delay between a change making it to Meta and making it to hosted sites. I don’t know the general timeline or if it differs by customer, but I usually see changes on Meta make it to the hosted site I use within a few days.
לייק 1
Can you reproduce this on meta? I just tried and could not reproduce the issue in the OP.
לייק 1
As noted, can’t reproduce this on meta but can reproduce it on both Fedora sites and on the Python one. So if you didn’t fix it on purpose, something is still wrong somewhere. :slight_smile:
Maybe these sites need to update.
Yes I think you’re right - this was fixed yesterday:
https://github.com/discourse/discourse/pull/15159
@mattdm I’ll run a deploy on your site right now, so the fix should be live in the next few minutes
2 לייקים
This also happens on my site, which I mentioned in my second edit in this topic.
לייק 1
אני אוודא שהתיקון הזה יופץ בכל שרתי הפרו/עסקי שלנו בשעה הקרובה בערך
Thank you so much!
I do like the feature in general — it is indeed quite convenient to write a paragraph and then go back and add in links on a whim.
לייק 1
Update - my site seems to be back to normal now. Thanks so much!
2 לייקים
This topic was automatically closed after 42 hours. New replies are no longer allowed.
