Dear Support.
After I add and remove Discord Bot Plugin, my plugin list does not show and not working.
This is my plugin list:
Dear Support.
Hi, could you copy/paste your app.yml here: http://www.yamllint.com/ ?
Is there any error thrown during rebuild ?
What does the update menu show in the admin settings? Do you see the plugins listed there? Maybe try another rebuild, just in case?
I dont see the plugin list.
I try to rebuild many times.
I think the problem when I add this code and remove:
hooks:
before_code:
- exec:
cmd:
- apt-get update
- apt-get install -y libsodium-dev
I follow this guide: Discord Sync: sync a Discourse forum with a Discord server
indentation seems off
ha ! no, you’re missing an s
at hook in your first post
should be:
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
OMG.
That’s problem!
Thank you!
I went over that code at least 10 times and missed that. Guess I need coffee.
