Laucher rebuild app doesn't load the plugins
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/discourse/discourse-ai.git
          - git clone https://github.com/discourse/discourse-chat-integration.git
          - git clone https://github.com/discourse/discourse-doc-categories.git
          - git clone https://github.com/discourse/discourse-gamification.git
          - git clone https://github.com/discourse/discourse-whos-online.git
          - git clone https://github.com/discourse/discourse-algolia.git
          - git clone https://github.com/discourse/discourse-staff-alias.git
          - git clone https://github.com/discourse/discourse-yearly-review.git
          - git clone https://github.com/discourse/discourse-reactions.git
          - git clone https://github.com/discourse/discourse-google-one-tap.git
          - git clone https://github.com/discourse/discourse-cakeday.git
          - git clone https://github.com/discourse/discourse-hcaptcha.git
          - git clone https://github.com/discourse/discourse-policy.git
          - git clone https://github.com/discourse/discourse-akismet.git
          - git clone https://github.com/discourse/discourse-gated-topics-in-category.git
          - git clone https://github.com/discourse/discourse-assign.git
          - git clone https://github.com/discourse/discourse-saved-searches.git
          - git clone https://github.com/discourse/discourse-fingerprint.git
          - git clone https://github.com/communiteq/discourse-private-replies.git
run:
./launcher rebuild app
dosent add the newly added plugin
no error
What am i missing
What program are you using for execution?
i didn’t understand you. sorry. can you explain a bit more on what do you mean by What program
What SSH program are you using to update the ./launcher rebuild app?
PuTTY: latest release (0.81)
i used the same before it has worked very well.
Did the rebuild complete and say that it was destroying and starting a new container?
What does
docker ps
show?
i have dm you
If anyone has similar problem
I have solved it by matching client and server version to match the API also.
then only it will help to build new plugins.
Before.
After
