Impossibile ricostruire l'app dopo aver installato questi plugin
Hello,
I am doing a test installation at DigitalOcean. However I am unable to Rebuild the App after adding some PLUGINS. The stance part is, even after I remove the Plugins I added, it still will not Rebuild.
The first Plugin in the Plugin code Block is what came with digitalOcean installation, so I followed same format. So, what could be wrong?
Here is the entire yaml file
Welcome to Ubuntu 22.04.4 LTS (GNU/Linux 5.15.0-113-generic x86_64)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/pro
 System information as of Sun Jul 14 23:46:41 UTC 2024
  System load:  0.0                Processes:             96
  Usage of /:   25.4% of 67.66GB   Users logged in:       0
  Memory usage: 11%
  Swap usage:   2%
Enable ESM Apps to receive additional future security updates.
See https://ubuntu.com/esm or run: sudo pro status
Welcome to the DigitalOcean Discourse 1-Click Application
On your first login you will be prompted to configure your Discourse installation.
All Discourse scripts and files may be found in /var/discourse and the setup
utility can be run again by launching discourse-setup in that directory.
For help and more information, visit https://do.co/3dmapBw
To delete this message of the day: rm -rf /etc/update-motd.d/99-one-click
root@xxxxx:~# cd /var/discourse
nano containers/app.yml
root@xxxxxx:/var/discourse# ./launcher rebuild app
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20240708-0023: Pulling from discourse/base
Digest: sha256:025e9c1f6848c4726544c6ae873d710c62f547b72afb7f537aaa44eb5377cb5c
Status: Image is up to date for discourse/base:2.0.20240708-0023
docker.io/discourse/base:2.0.20240708-0023
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-07-14T23:48:26.474524 #1]  INFO -- : Reading from stdin
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/merge_command.rb:50:in `merge': no implicit conversion of String into Hash (TypeError)
      first.merge(second, &merger)
	from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/merge_command.rb:50:in `deep_merge'
	from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/cli.rb:61:in `block in run'
	from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/cli.rb:57:in `each'
	from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/cli.rb:57:in `run'
	from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/bin/pups:9:in `<top (required)>'
	from /usr/local/bin/pups:25:in `load'
	from /usr/local/bin/pups:25:in `<main>'
b32a86eece508c0f95a8edacaf4ab693200cd5c64d54dea565466219f6d65e7f
root@xxxxx:/var/discourse# ./discourse-doctor
DISCOURSE DOCTOR Sun Jul 14 23:48:49 UTC 2024
OS: Linux ogatrainer 5.15.0-113-generic #123-Ubuntu SMP Mon Jun 10 08:16:17 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
Found containers/app.yml
==================== YML SETTINGS ====================
DISCOURSE_HOSTNAME=xxxxxxxxxxxxxxx
SMTP_ADDRESS=xxxxxxxxxxxxxxxx
DEVELOPER_EMAILS=xxxxxxxxxxxx
SMTP_PASSWORD=xxxxxxxxxxxx
SMTP_PORT=xxx
SMTP_USER_NAME=xxxxxxxxxxxxx
LETSENCRYPT_ACCOUNT_EMAIL=me@example.com
==================== DOCKER INFO ====================
DOCKER VERSION: Docker version 27.0.3, build 7d4bcd8
DOCKER PROCESSES (docker ps -a)
CONTAINER ID   IMAGE                 COMMAND        CREATED      STATUS                      PORTS     NAMES
aa1792677667   local_discourse/app   "/sbin/boot"   2 days ago   Exited (5) 23 minutes ago             app
==================== SERIOUS PROBLEM!!!! ====================
app not running!
Attempting to rebuild
==================== REBUILD LOG ====================
Fetching origin
app
I, [2024-07-14T23:48:56.604647 #1]  INFO -- : Reading from stdin
b9a2b268dd5c4ea7a1c3c878bb3bb9c121a068b543239cc4210180e2089ea888
==================== END REBUILD LOG ====================
Failed to rebuild app.
Checking your domain name . . .
Connection to xxx.xxxxx.com succeeded.
You should probably remove any non-standard plugins and rebuild.
Attempting to restart existing container. . .
starting up existing container
+ /usr/bin/docker start app
Error response from daemon: driver failed programming external connectivity on endpoint app (830abdf507c266ee25442d83f063be25c235c2d0710065d32a3ad9157f318d5c): failed to bind port 0.0.0.0:443/tcp: Error starting userland proxy: listen tcp4 0.0.0.0:443: bind: address already in use
Error: failed to start containers: app
Failed to restart the container.
==================== PLUGINS ====================
          - git clone https://github.com/discourse/discourse-reactions.git
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/paviliondev/discourse-landing-pages.git
          - git clone https://github.com/discourse/discourse-post-voting.git
          - git clone https://github.com/discourse/discourse-calendar.git
          - git clone https://github.com/discourse/discourse-topic-voting.git
          - git clone https://github.com/discourse/discourse-zoom.git
          - git clone https://github.com/discourse/discourse-follow.git
          - git clone https://github.com/discourse/discourse-ai.git
          - git clone https://github.com/discourse/discourse-subscriptions.git
          - git clone https://github.com/discourse/discourse-affiliate.git
          - git clone https://github.com/discourse/discourse-gamification.git
          - git clone https://github.com/discourse/discourse-adplugin.git
          - git clone https://github.com/discourse/discourse-whos-online.git
          - git clone https://github.com/discourse/discourse-signatures.git
          - git clone https://github.com/discourse/discourse-cakeday.git
          - git clone https://github.com/discourse/discourse-user-notes.git
          - git clone https://github.com/discourse/discourse-akismet.git
          - git clone https://github.com/procourse/procourse-static-pages.git
WARNING:
You have what appear to be non-official plugins.
If you are having trouble, you should disable them and try rebuilding again.
See https://github.com/discourse/discourse/blob/main/lib/plugin/metadata.rb for the official list.
Discourse version at xxx.xxxxxx.com: NOT FOUND
Discourse version at localhost: NOT FOUND
==================== MEMORY INFORMATION ====================
RAM (MB): 2059
               total        used        free      shared  buff/cache   available
Mem:            1963         214        1299           3         449        1588
Swap:           2047          46        2001
==================== DISK SPACE CHECK ====================
---------- OS Disk Space ----------
/dev/vda1        68G   18G   51G  26% /
==================== DISK INFORMATION ====================
Disk /dev/loop0: 87.03 MiB, 91258880 bytes, 178240 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 38.83 MiB, 40714240 bytes, 79520 sectors
Disk /dev/loop2: 63.29 MiB, 66359296 bytes, 129608 sectors
Disk /dev/loop3: 49.84 MiB, 52260864 bytes, 102072 sectors
Disk /dev/loop4: 111.95 MiB, 117387264 bytes, 229272 sectors
Disk /dev/loop5: 63.95 MiB, 67051520 bytes, 130960 sectors
Disk /dev/vda: 70 GiB, 75161927680 bytes, 146800640 sectors
Disklabel type: gpt
Disk identifier: C2901603-FAE8-45CB-86FE-13D02E6B6DC6
Device      Start       End   Sectors  Size Type
/dev/vda1  227328 146800606 146573279 69.9G Linux filesystem
/dev/vda14   2048     10239      8192    4M BIOS boot
/dev/vda15  10240    227327    217088  106M EFI System
Partition table entries are not in disk order.
Disk /dev/vdb: 472 KiB, 483328 bytes, 944 sectors
==================== END DISK INFORMATION ====================
Last login: Sun Jul 14 23:46:42 2024 from xxx.xxx.xxxx
root@xxxxxxx:~# cd /var/discourse
root@xxxxxxx:/var/discourse# ./launcher rebuild app
Fetching origin
app
I, [2024-07-15T00:40:19.347084 #1]  INFO -- : Reading from stdin
22325d070d60382ffc6f404d14ee2be77c418596cb35edd4c967ffcbef5754eb
root@xxxxxx:/var/discourse# cd ..
root@xxxxxx:/var# cd ..
root@xxxxxx:/# cd /var/discourse
  GNU nano 6.2                                                   containers/app.yml
es## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  ## Uncomment the next line to enable the IPv6 listener
  #- "templates/web.ipv6.template.yml"
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
Questa forma di installazione non è supportata qui. Devi utilizzare un VPS di base e seguire invece il processo di installazione standard.
Non fa semplicemente un’installazione standard sotto il cofano?
Quali nuovi plugin hai installato?
A naso, guardando il tuo file, commenta il plugin “procourse”. È l’ultimo nell’elenco.
Il plugin originale non è più mantenuto. Esiste un fork.
Detto questo, potrebbe essere di nuovo rotto a causa di modifiche al core.
Quando si installano i plugin è un po’ un problema. Ma aggiungi una ricompilazione, controlla il sito se la ricompilazione ha successo e il sito funziona. Procedi all’installazione del plugin successivo.
Non ne ho idea, ma questi post passati mi hanno reso diffidente nei suoi confronti.
Per prima cosa rimuoverei i plugin procourse e pavilion.
Grazie a tutti. Ho semplicemente abbandonato l’installazione su Digital Ocean dato che non è supportata. Ho quindi seguito il percorso di installazione standard documentato e supportato dalla community, ma il mio nuovo problema è che l’email di attivazione iniziale NON viene inviata. Abbastanza strano.
