Plugins & Theme-Komponenten bestanden den Neubau, sind aber nicht verfügbar?
Gemäß der Dokumentation habe ich einige Theme-Komponenten und Plugins in der YAML-Datei hinzugefügt:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-reactions.git
          - git clone https://github.com/paviliondev/discourse-ratings.git
          - git clone https://github.com/discourse/reader-mode.git
          - git clone https://github.com/VaperinaDEV/discourse-modal-grip.git
          - git clone https://github.com/nolosb/discourse-tag-styles.git
          - git clone https://github.com/merefield/discourse-tc-tag-cloud.git
Der ./launcher rebuild scheint erfolgreich zu sein:
I, [2024-05-16T10:49:19.172929 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-05-16T10:49:19.173814 #1]  INFO -- : > cd /var/www/discourse/plugins & git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2024-05-16T10:49:20.511901 #1]  INFO -- :
I, [2024-05-16T10:49:20.512493 #1]  INFO -- : > cd /var/www/discourse/plugins & git clone https://github.com/discourse/discourse-reactions.git
Cloning into 'discourse-reactions'...
I, [2024-05-16T10:49:21.315121 #1]  INFO -- :
I, [2024-05-16T10:49:21.315491 #1]  INFO -- : > cd /var/www/discourse/plugins & git clone https://github.com/paviliondev/discourse-ratings.git
Cloning into 'discourse-ratings'...
I, [2024-05-16T10:49:21.917044 #1]  INFO -- :
I, [2024-05-16T10:49:21.917367 #1]  INFO -- : > cd /var/www/discourse/plugins & git clone https://github.com/discourse/reader-mode.git
Cloning into 'reader-mode'...
I, [2024-05-16T10:49:22.499069 #1]  INFO -- :
I, [2024-05-16T10:49:22.499672 #1]  INFO -- : > cd /var/www/discourse/plugins & git clone https://github.com/VaperinaDEV/discourse-modal-grip.git
Cloning into 'discourse-modal-grip'...
I, [2024-05-16T10:49:23.030998 #1]  INFO -- :
I, [2024-05-16T10:49:23.031349 #1]  INFO -- : > cd /var/www/discourse/plugins & git clone https://github.com/nolosb/discourse-tag-styles.git
Cloning into 'discourse-tag-styles'...
I, [2024-05-16T10:49:23.535520 #1]  INFO -- :
I, [2024-05-16T10:49:23.535773 #1]  INFO -- : > cd /var/www/discourse/plugins & git clone https://github.com/merefield/discourse-tc-tag-cloud.git
Cloning into 'discourse-tc-tag-cloud'...
I, [2024-05-16T10:49:24.330857 #1]  INFO -- :
I, [2024-05-16T10:52:07.932848 #1]  INFO -- : > cd /var/www/discourse & su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2024-05-16T10:52:15.062445 #1]  INFO -- : discourse-modal-grip is already at latest compatible version
discourse-ratings is already at latest compatible version
discourse-reactions is already at latest compatible version
discourse-tag-styles is already at latest compatible version
discourse-tc-tag-cloud is already at latest compatible version
docker_manager is already at latest compatible version
reader-mode is already at latest compatible version
Aber die Seite wurde mit nur einigen von ihnen neu gestartet. Nur eines davon befindet sich unter /admin/customize/components und andere habe ich durch die Suche auf der Einstellungsseite gefunden.
Ist dies ein Kompatibilitätsproblem mit Version 3.3.0b3? Wo kann ich es in den Protokollen sehen, um zu sehen, was dazu führt, dass einige von ihnen übersprungen werden, wie Discourse-Ratings, reader-mode usw.
So installiert man Plugins. Um Theme-Komponenten zu installieren, müssen Sie jedoch Installing a theme or theme component befolgen.
Ich habe das versucht, aber ich erhielt die Meldung, dass die GIT-URL keine Themenkomponente enthält. Daher habe ich den anderen Weg versucht. Ich sehe, was passiert ist. Es lässt die discourse-ratings immer noch aus, sie sind auf keine Weise installiert.
Dies sind Theme-Komponenten.
Entfernen Sie diese aus Ihrer app.yml-Datei und folgen Sie der Dokumentation, um sie zu installieren:
Ja. Habe diese 4 entfernt und sie tatsächlich als Komponenten hinzufügen können, aber ich habe immer noch discourse-ratings, das installiert ist und in den Einstellungen angezeigt wird, aktiviert ist, aber keine Widgets in den Themen angezeigt werden. Ich werde mich dann darauf konzentrieren. Danke für die Hilfe!
