ברירות מחדל בסקר
Install this theme component
This simple theme component allows some control over the default poll behaviour. It was inspired by this Topic:
Other settings could easily be added if needed.
9 לייקים
THANK YOU! I’ve already got this installed on my forum and I’m looking forward to fewer “Oops” moments for the folks who participate on our forum.
4 לייקים
This looks to be broken at the mo:
I’ll take a look when I get the chance, but PRs are always welcome!
לייק 1
@nathank
I was looking at this code:
I think you can do the following:
api.modifyClass("component:modal/poll-ui-builder", {
  pluginId: 'poll-defaults',
  didInsertElement() {
    this._super(...arguments); // super.didInsertElement(...arguments); doesn't work (?)
    if (settings.Public) {this.set('publicPoll', true)}
    if (settings.Advanced) {this.set('showAdvanced', true)}
It works.
However, I’m perplexed with didInsertElement.
poll-ui-builder is now a glimmer component. didInsertElement is not supposed to exist based on the ember upgrading guide.
I can see in core some usage. Maybe some specificity in Discourse?
Also, I’m not sure why super.didInsertElement doesn’t exist in this above code context.
לייק 1
This is now part of core: :partying_face:
https://github.com/discourse/discourse/pull/24332
3 לייקים
Nice!! This makes the TC nicely obsolete. I consider this mission accomplished :wink:
3 לייקים
So .. how do we change the default to private ?
There is a site setting
2 לייקים
Thanks !
