The save draft modal is now at the bottom of the screen instead of in the middle. Is that an intentional change?
          I still expect all those modals to appear at the center. Some also still show there while others don’t. For example, when you close a draft, you have to look at the bottom, but when you open it again, then those modals are centered.
Also, the discard button is exactly in the same position as the bin, so it is more likely that you accidentally delete your draft.
I think I’d also still prefer if the desktop and mobile versions worked the same. Using a tablet often feels like something in between because you use Discourse in desktop mode, but it is a touch device. That’s why I expect those modals to appear in the same place on tablet and mobile.
