When a link is attached in a post, it shows a topic name and click counter, a normal and expected function. However, when you change the topic name for the attached link, it doesn’t automatically change the topic name, and the click counter resets to zero. After you click on “rebuild HTML,” it’ll reset the topic name, but the click counter stays at zero, regardless of clicks. Is this an expected function?
I felt that when the topic name was changed, it should automatically update the topic name without having to click “rebuild HTML,” and the click counter shouldn’t reset to zero. I also feel Discourse team must be having calculated reason for doing this, but I genuinely felt this is a hassle in terms of admin experience.
