Thanks for bringing that up @Andrew8H! Should be fixed with:
For all others - make sure your Discourse site had been updated after 2021-03-17T07:00:00Z before updating this component.
cc @angus
cc @angus
Perfect! Fixed! Splendid support as per usual. Thank you @tshenry
Hi all,
After installing this component, most of the icons on the page disappear and I’m seeing this error in the console.
Uncaught Error: Could not find module @ember/runloop imported from `discourse/initializers/initialize-discourse-post-badges
Is there something else I should be adding/editing? Thanks!
Hmm, I am not able to reproduce the error. A few things to check on:
Thank you for the quick reply, I’m using Discourse 2.3.2 which looks quite old. On the settings, they are still on defaults. I don’t believe there are any plugins, this was the first component I installed.
It sounds like an upgrade may be needed?
Yes, 2.3.2 is very old at this point. You will definitely want to upgrade, and for reasons that go well beyond compatibility with this component
Ugh. I missed this warning. I’m running Discourse 2.6.3. I’m assuming that came out before March 17, since I lost my custom images. Is there any way for me to downgrade this component?
Let me add a workaround. Hang tight.
Edit: @jtbayly it should work now if you update the component. Sorry for the trouble! I’ll try to be more careful about backwards compatibility going forward.
Thanks much. Worked like a charm.
We seem to be getting more 429 errors these days due to this add-on (I can’t put my finger on when that started, but I’d say in the last 2-3 months). Are there still plans to reduce the number of requests?
Unfortunately, it doesn’t seem that time has permitted yet for the core changes that would be required. The priority is probably going to be even lower now that there is a plugin that handles it in a more graceful manner:
If the component is becoming an issue for your community, I would highly recommend switching over the the plugin if possible.
Sorry to not have better news!
I took a look, but the functionality is different from the TC: in the plugin, users can set which badges to show. In the TC, the site admin decides. I’ll see if I can fork it to make it do what I need.
That’s my use case as well. Let’s us know if you get it working, please.
How do you setup the plugin? Do you use your theme component?
Ah okay read some later posts where moved to user end.
This component has issues with New installs will default to Ember CLI builds in Production
_application-fe5f714a0b25da04a163bd904e96336e.js:6171
An error occurred in the "Post Badges" theme/component: TypeError: Cannot read properties of undefined (reading 'currentProp')
at 6dd3e4df7d5d30781da2109aaad4015405b3f832.js?__ws=discourse.myforum.tld:108
at e.withPluginApi (_application-fe5f714a0b25da04a163bd904e96336e.js:4070)
at Object.initialize (6dd3e4df7d5d30781da2109aaad4015405b3f832.js?__ws=discourse.myforum.tld:107)
at Object.s.initialize (_application-fe5f714a0b25da04a163bd904e96336e.js:60)
at _vendor-89acebf53895afcc5339ec7eda71567e.js:2730
at e.each (_vendor-89acebf53895afcc5339ec7eda71567e.js:4074)
at e.walk (_vendor-89acebf53895afcc5339ec7eda71567e.js:4064)
at e.each (_vendor-89acebf53895afcc5339ec7eda71567e.js:4056)
at e.topsort (_vendor-89acebf53895afcc5339ec7eda71567e.js:4056)
at n._runInitializer (_vendor-89acebf53895afcc5339ec7eda71567e.js:2733)
(anonymous) @ _application-fe5f714a0b25da04a163bd904e96336e.js:6171
_application-fe5f714a0b25da04a163bd904e96336e.js:4072
To prevent errors, add a `pluginId` key to your changes when calling `modifyClass`
ie @ _application-fe5f714a0b25da04a163bd904e96336e.js:4072
Thanks for the report, that should be fixed now.
Hello, Great work on this theme component! I also feel that it should be part of the core
I’m curious since there hasn’t been much activity here for a while, would you still recommend using the plugin over the theme component? Is the plugin official / is it well maintained?
Any ideas if this will become a core feature?
Thanks again
Is the plugin that @angus created working for anyone? Doesn’t seem to work for me, and it’s still the recommended way to use this. Would be very nice to see this supported by the team in plugin form. Thanks!
@davidkingham Have you managed to get the plugin running? We are looking into it as well.
No, I’ve given up on this unfortunately.
