يتم تشغيل حدث "تم إنشاء المنشور" عند إنشاء الموضوع
Working with the internal event hooks and I noticed, when the topic_created event triggers so does post_created. For the initial topic post, wouldn’t the assumption be that a post was created as well?
Is there a reason why they both would fire at the same time? It seems redundant to have both fire at the same time, especially because you cannot create a topic without an inital post.
Ex:
DiscourseEvent.on(:topic_created) do |topic|
    puts "New Topic"
DiscourseEvent.on(:post_created) do |post|
   puts "New post"
It is by design. If post_created event skipped in topic creations then the code which only listening post_created events won’t be executed.
Ah that makes sense just seemed odd to me at first glance.
