Impostazioni Postman per istanza controllata Memberful SSO
Trying to use Postman to do a basic query, it fails returning the login html. Am I getting these site setting correct for a Memberful SSO instance?
I have another non-SSO instance where Postman is working fine.
The API Gem works fine on the above SSO-controlled instance using regular credentials:
client = DiscourseApi::Client.new('https://discourse.gomomentum.org/')
client.api_key = ENV['REMOTE_DISCOURSE_API']
client.api_username = 'an_admin_username'
Since you’re using SSO, the login HTML isn’t part of the Discourse site - it is part of the SSO provider.
If you want to obtain the HTML for the login page, you need to make a normal request to https://discourse.gomomentum.org/, without an API key, and follow the HTTP redirect chain. (although, I’m not sure why you want the login HTML, that seems like an unusual requirement…)
If you just want a way to test the API, make a request for https://discourse.gomomentum.org/about.json. You just need the API key and username, no need for any SSO information.
Thanks @david. Sorry for the confusion. I did not want the html, but was just saying it was failing and returning html vs. what I wanted, json.
That said, for some reason it all the sudden is working now on firing Postman back up. No idea what changed, but the auth is working fine now.
Thanks!
