Postmark bounce support?
I’m a big fan of Postmarkapp.com
We use their bounce API to create tickets when emails need attention.
What would it take to expand Discourse’s Bounce Processing to support Postmark?
See:
3 „Gefällt mir“
We only support adding these sorts of things for mail services that have a free tier. Otherwise it doesn’t benefit enough people.
And for our hosted customers, we handle all email, so there’s no reason to do it for our customers.
3 „Gefällt mir“
Also, we haven’t used any “Bounce API” but rather “Bounce Webhooks” which is documented here
5 „Gefällt mir“
Would you consider a PR for postmark bounce webook support now? mailgun, one of the officially supported bounce providers, has now moved away their free tier. I get the impression that free-tiers are generally going away in this industry: Tell HN: Mailgun lowers free-tier API from 10k to 625 emails per month | Hacker News
3 „Gefällt mir“
A PR would certainly be considered. Please communicate early if this providers differs too much from the current supported ones so we can offer feedback on the mergeability of your approach.
6 „Gefällt mir“
I’ve got this that I’m about to submit a PR.
Using the test curl command that they document here on my development instance it looks like it will work.
I included spec tests for both hard and soft bounces.
EDIT: I’ve now done tests triggering from their webhook test interface and it looks like it actually works.
I think this should be OK: add postmark webhook handling by pfaffman · Pull Request #8919 · discourse/discourse · GitHub
6 „Gefällt mir“
It’s merged! Thanks!
5 „Gefällt mir“
@wesochuck suggests the following changes to Bounce types (see Bounce API | Postmark Developer Documentation for definitions of bounce types, though I’ve included them below).
To hard_bounces add:
  • BadEmailAddress – “Invalid email address — The address is not a valid email address.”
  • Blocked " ISP block — Blocked from this ISP due to content or blacklisting."
To Soft bounces add:
  • SMTPApiError – " SMTP API error — An error occurred while accepting an email through the SMTP API."
  • DMARCPolicy – “DMARC Policy — Email rejected due DMARC Policy.”
I think that blocked makes sense, but I’m not sure about the rest. Let me know what you think and I’ll make the PR accordingly.
More info — The Postmark PR to handle webhooks doesn’t work
Sorry, but my PR doesn’t work.
First, Postmark throws away the message-id by default.
Second, the MessageID that Postmark includes in the webhook isn’t the Message-ID that is in the message.
From: Everything you need to know about SMTP (Simple Mail Transfer Protocol) | Postmark
Is there an easy way to add a X-PM-KeepID: true header in outgoing mail? Could that be added to core?
If that problem gets solved, then I’ll see about whether there is a way to have the actual Message-ID included in the webhook payload and process it accordingly.
4 „Gefällt mir“
