Posts on-save processing with regex/replace configurable in admin panel
meglio proposed a feature to configure regex/replace rules in the admin panel to automatically fix minor issues in posts as they are saved. The suggested rules would have two inputs: Regex and Replace with, optionally using regex references.
Examples of potential rules include:
  • Adding empty lines between paragraphs
  • Placing spaces after commas (locale-specific)
  • Removing links to websites from which smile embed codes were copied
  • Positioning large images with empty lines before and after
Mittineague suggested using a plugin that utilizes “Dialect”, but meglio clarified that they would like a configurable solution, not a hardcoded plugin.
If often fix minor issues in posts manually going through all of the posts on my forum on a daily basis. It turns out that most of the issues are typical and I could write a regex/rewrite rule to force the fix as soon as the message is posted or edited.
It would be nice to have such a section in admin panel with a set of rules, 2 inputs each:
  1. Regex (optionally introduces regex references)
  2. Replace with (optionally uses regex references)
Examples
  • Make empty lines between paragraphs
  • Place space after comma if not inside a number (this rule is specific to Russian / Ukrainian locale)
  • Remove links to websites from which smile embed codes were copied, i.e. [url=...][img...][/url]
  • Place large images on their own lines and enforce an empty line before and after
Have you tried doing any of this with a plugin utilizing “Dialect”?
Nope, may you please clarify what you mean.
Something like the Pirate Speak plugin. eg.
post text is passed into an anonymous function
Discourse.Dialect.postProcessText(function (text)
and a custom function “parses and manipulates” the text
3 curtidas
I see. No, my proposition is actually about a different thing. It may be a plugin, but configurable by admin, not hardcoded per-forum.
