Preference: Automatically Watch Topic when I am @mentioned, quoted, or invited
On some other systems, once you are “mentioned” you are automatically watching that topic.
I think this would be useful for communities who are used to such behavior, and/or where login is required and the members already have a high level of trust with each other.
Here’s my proposal for this feature:
Other
When someone quotes me, mentions my @username, or invites me to a topic, set that topic to [ Watched | Tracked | Normal ] default is Normal.
The specific proposal above is based on the verbiage in the existing user preference (below) and the proposed spec for this other feature request here: Automatically set Topics to Watching after posting
3 curtidas
This seems rather extreme, as anyone could force you into a rather high level of notifications on a topic, basically against your will. I can’t recall hearing any custome ever ask for this?
1 curtida
Assuming the preference defaults to off, the user should be consciously aware of that when turning this on. From the description, it is clear that other users trigger the bump in notification level.
I can see where this is useful, particularly in mailing-list mode. Say I watch the cat category. I get emails for all posts there. A user mentions me in the jaguar category, which I don’t watch. I’ll get the email about that post, but nothing afterwards. This would fix that.
1 curtida
I think it is fair for an “internal” discourse instance where everyone is trusted. For public instances it seems very scary.
6 curtidas
This edge use case will be further mitigated by having the track-status changeable from the always-visible sidebar menu. Once you follow that mention, quote or invite to a post mid-stream, you can immediately decide whether to start watching this topic or leave it be.
5 curtidas
Trust your community by default. Let the admin turn it off if it gets abused?
Uh, no, it is the opposite. Safe by default, let risky potentially damaging or dangerous features be manually enabled by admins.
5 curtidas
Olá a todos,
Somos novos no Discourse e atualmente estamos migrando do Slack para uma comunidade privada do Discourse para o nosso negócio. São cerca de 50 usuários ativos, e muitos tópicos estão sendo criados e mensagens estão sendo postadas.
Como muitas mensagens são enviadas e tópicos criados, ninguém conseguirá acompanhar tudo. Por isso, atualmente marcamos pessoas quando há um tópico que elas não devem perder.
Um desafio que enfrentamos é tornar tudo o mais intuitivo possível para usuários com pouca ou nenhuma experiência com fóruns / Discourse.
Adicionamos “Não lidos” à barra lateral. Seria útil se mensagens em que alguém é mencionado também aparecessem sob “Não lidos”. Assim, as pessoas precisariam verificar apenas um lugar.
Para usuários que não estão familiarizados com o funcionamento de fóruns, confiar apenas na aba “Não lidos” simplificaria a experiência deles e garantiria que não perdessem discussões importantes.
Desculpe postar em um tópico antigo — se isso for inadequado, sinta-se à vontade para remover esta mensagem. Mas eu gostaria de saber se há ainda planos para adicionar essa opção?
1 curtida
