Ability to change tracking level from topic summary
As some of our users have pointed out, it is frustrating to only be able to change the topic tracking at the bottom of a topic. The problem scenario was outlined as follows:
  1. Set auto track rules to something like 4 minutes in topic.
  2. Browse from a touch device, such as a tablet.
  3. See a new long topic that piques your interest. get 10 or so posts in and realize that, while you are interested in the topic, you aren’t interested enough to devote the time in the topic now.
  4. You haven’t yet spent 4 minutes in the topic, so it hasn’t auto-tracked. Being on a touch device, you can’t use the keyboard shortcuts. Down to the bottom of the topic you go to set the tracking-status manually.
  5. Now that you’ve been at the bottom of the topic, your furthest read position is the last post. The topic does not show in the Unread list. Your position in the topic is lost. :sob:
To combat this, the idea of adding the ability to change the tracking status from the top of the topic was suggested (thank you @boomzilla). Adding the selector to the topic summary area would seem a logical place to double this control, and would resolve the above scenario fairly easily.
「いいね!」 11
I’ve had users lament about this too, and I agree it’s a problem.
[quote=“abarker, post:1, topic:28512”]
[/quote]Hmmm, interesting idea. Could you make a mockup of how it might fit in there though?
「いいね!」 2
Here’s another rough thought along these lines:
https://meta.discourse.org/t/sticky-footer-for-progress-bar-and-topic-buttons/20672?u=mcwumbly
「いいね!」 1
I’m more in favour of fully utilising the right-hand sidebar…
As seen on esoTalk and Flarum.
That would pave the way for ‘Natural breakpoints or “chapters” for long topics’ as well.
「いいね!」 5
[quote=“erlend_sh, post:2, topic:28512, full:true”]
A couple ideas:
The great thing about this option is that it can be put in place for both desktop and mobile UIs.
These sound like acceptable ideas for desktop, but then what about mobile? The entire point of putting the control in a second location is that it is currently only accessible at the bottom for people who have no keyboard access. Most users who have no keyboard access are on mobile, which means that the sidebar solution won’t help them at all.
「いいね!」 3
Is at least part of this problem solved by using bookmarks? Maybe with an option to auto-track topics that have bookmarked posts in them.
Edit - just as a potential alternative. Might even be easier on mobile, since it would require less navigation within the topic.
「いいね!」 2
I like that idea.
Currently, when I’m interested in reading a topic, but want to do so at a later time, that’s what I do, Bookmark it.
Then when I have more time, I go to my Bookmarks and find it.
Having Bookmarks Tracked (or Watched) automatically would help save a bit of work sometimes.
「いいね!」 1
There is definitely lots of prior art on putting controls at the top and bottom, we already have a fair number of controls in the topic summary and it is collapsed by default for shorter topics so I think duplicating it there is a good idea.
The bookmark idea is interesting too but it would not be very discoverable, and I assume it would only apply if you bookmarked the topic? Feels a bit magical to me, not discoverable.
「いいね!」 3
I was thinking either - you could bookmark a post or the topic itself and it’d watch the thread either way. It’d be similar to reading for x minutes or replying, another way of indicating interest that switches the thread over to watched mode.
I’m not married to the idea or anything though, this isn’t a use case that’s particularly relevant to me so if putting the control at the top works better, it works better. :slight_smile:
The initial complaint I saw did mention this, but then said they discarded the idea because the bookmarks get lost among all their other bookmarks. The idea is to have the topic appear on the Unread list.
That seems problematic to me. When setting a bookmark, does the user want to watch or track the topic? Maybe they were checking out a new topic, found a post with some information they want to hold onto, but found the topic as a whole useless, then the topic should be left as regular. What if they’re bookmarking it to flag later, should the tracking status be changed for that?
There are so many different potential uses for bookmarks that changing the tracking status when a bookmark is set seems like the wrong approach.
That’s a really good point, I think. I’d favor a topic summary button over tracking bookmarks after taking this into account.
In light of the new vertical timeline, I think we should re-consider this. It’s even in the spec’s mockup:
Right now we’re occupying that space with the admin’s topic wrench, but I think the tracking button is more important. In fact, I’d say there’s still room for both. And when the sidebar is collapsed, the wrench can be moved down into the paging-widget.
「いいね!」 1
This has always been the plan from the start. (That is why it was in the original mockup.) It just takes time for Robin to work the code into shape to make it happen.
「いいね!」 1
Right, sorry I jumped the gun here. Seeing that wrench taking its place was making me antsy :sweat_smile:
「いいね!」 3
This is now complete as of 1.6 beta.
