Sendgrid error: NoMethodError (método no definido `[]' para nil:NilClass)
Hemos invitado a unas 40.000 usuarios mediante una invitación masiva y hemos obtenido algunos de estos errores en los registros:
NoMethodError (método [] no definido para nil:NilClass) app/controllers/webhooks_controller.rb:19:in block in sendgrid app/controllers/webhooks_controller.rb:15:in each app/controllers/webhooks_con
Seguimiento de la pila:
Resumen
1:25 pm
app/controllers/webhooks_controller.rb:19:in `block in sendgrid'
app/controllers/webhooks_controller.rb:15:in `each'
app/controllers/webhooks_controller.rb:15:in `sendgrid'
actionpack (6.0.3.3) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (6.0.3.3) lib/abstract_controller/base.rb:195:in `process_action'
actionpack (6.0.3.3) lib/action_controller/metal/rendering.rb:30:in `process_action'
actionpack (6.0.3.3) lib/abstract_controller/callbacks.rb:42:in `block in process_action'
activesupport (6.0.3.3) lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack (6.0.3.3) lib/abstract_controller/callbacks.rb:41:in `process_action'
actionpack (6.0.3.3) lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack (6.0.3.3) lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
activesupport (6.0.3.3) lib/active_support/notifications.rb:180:in `block in instrument'
activesupport (6.0.3.3) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (6.0.3.3) lib/active_support/notifications.rb:180:in `instrument'
actionpack (6.0.3.3) lib/action_controller/metal/instrumentation.rb:32:in `process_action'
actionpack (6.0.3.3) lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
activerecord (6.0.3.3) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (6.0.3.3) lib/abstract_controller/base.rb:136:in `process'
actionview (6.0.3.3) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (2.1.0) lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method'
actionpack (6.0.3.3) lib/action_controller/metal.rb:190:in `dispatch'
actionpack (6.0.3.3) lib/action_controller/metal.rb:254:in `dispatch'
actionpack (6.0.3.3) lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
actionpack (6.0.3.3) lib/action_dispatch/routing/route_set.rb:33:in `serve'
actionpack (6.0.3.3) lib/action_dispatch/journey/router.rb:49:in `block in serve'
actionpack (6.0.3.3) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (6.0.3.3) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (6.0.3.3) lib/action_dispatch/routing/route_set.rb:834:in `call'
lib/middleware/omniauth_bypass_middleware.rb:68:in `call'
rack (2.2.3) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.3) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.3) lib/rack/head.rb:12:in `call'
lib/middleware/anonymous_cache.rb:336:in `call'
rack (2.2.3) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.3) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/cookies.rb:648:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/actionable_exceptions.rb:17:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
logster (2.9.4) lib/logster/middleware/reporter.rb:43:in `call'
railties (6.0.3.3) lib/rails/rack/logger.rb:37:in `call_app'
railties (6.0.3.3) lib/rails/rack/logger.rb:28:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/request_id.rb:27:in `call'
lib/middleware/enforce_hostname.rb:22:in `call'
rack (2.2.3) lib/rack/method_override.rb:24:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.3) lib/rack/sendfile.rb:110:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/host_authorization.rb:76:in `call'
rack-mini-profiler (2.1.0) lib/mini_profiler/profiler.rb:235:in `call'
message_bus (3.3.2) lib/message_bus/rack/middleware.rb:61:in `call'
lib/middleware/request_tracker.rb:176:in `call'
railties (6.0.3.3) lib/rails/engine.rb:527:in `call'
railties (6.0.3.3) lib/rails/railtie.rb:190:in `public_send'
railties (6.0.3.3) lib/rails/railtie.rb:190:in `method_missing'
rack (2.2.3) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.3) lib/rack/urlmap.rb:58:in `each'
rack (2.2.3) lib/rack/urlmap.rb:58:in `call'
unicorn (5.7.0) lib/unicorn/http_server.rb:632:in `process_client'
unicorn (5.7.0) lib/unicorn/http_server.rb:728:in `worker_loop'
unicorn (5.7.0) lib/unicorn/http_server.rb:548:in `spawn_missing_workers'
unicorn (5.7.0) lib/unicorn/http_server.rb:144:in `start'
unicorn (5.7.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `load'
vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `<main>'
Entorno (oculto):
hostname example-production-app
process_id 487750
application_version 902fbd0b7e588431788396be28256ed9725c15c1
HTTP_HOST www.example.com
REQUEST_URI /webhooks/sendgrid
REQUEST_METHOD POST
HTTP_USER_AGENT SendGrid Event API
HTTP_X_FORWARDED_FOR XXX.XX.XX.XX
HTTP_X_REAL_IP XXX.XX.XX.XX
time 1:25 pm
Estamos en la última versión de Discourse.
¿Alguien?
Seguimos recibiendo muchos de estos errores.
¿Qué es esto? Todos los errores de un usuario con un correo electrónico de Gmail correcto como correo principal de la cuenta:
Esto se ha solucionado: Digest send failures since update (NoMethodError) - #17 by Falco
