Problem, rebuild to latest version
Hi,
when I try to rebuild app to latest version with this add-ons on:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/jonmbake/discourse-ldap-auth.git
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/angusmcleod/discourse-qa.git
          - git clone https://github.com/discourse/discourse-voting.git
          - git clone https://github.com/discourse/discourse-chat-integration.git
I cannot build it properly. And i received this error:
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake assets:precompile' failed with return #<Process::Status: pid 500 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake assets:precompile'"]}
5e2de95480cbc5131ed5a54998d303fd6d8e4f6f0fd2058d4878740bb99aeab2
or
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 6929 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
f920fb8b608312a02f07ef2c612342505b5bf1ad7d7d270c6c98cc5b2e48b287
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
Could you please help me with that?
I would try to disable non-official plugins (for example: discourse-qa, discourse-ldap-auth), and tried to rebuild again.
Now, I have only two official and I received the same error.
It’s build only when i put version: stable.
Did you try to change to stable after you had been in tests passed? You’ll need to wait until stable catches up. You can’t go backward.
I did cleanup almost every time.
I also clear shared folder.
And despite this, I receive these messages.
Change back to tests-passed until the next major release.
Version tests-passed don’t want to build.
Currently only two versions v2.2.5 and v2.2.6 are build.
I found out for me it was because I was still on Postgres 9, while 10 is now required. I upgraded to Postgres 11 and was to rebuild the app.
FWIW, PG12 is now supported and what is used on Standard Installations.
I am getting the same error in my latest attempt to upgrade to Discourse version 2.7.0.beta2. Uninstalling the unofficial plugins does not resolve the issue:
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 3977 exit 1>
6a0ecc8892255037b0997d720b2e2eaf3eb26427a3ec0bbbfa40861edafbe91e
When I tried upgrading discourse via dashboard, the following error is shown:
1 migrations failed!
Failed to migrate default
#<StandardError: An error has occurred, this and all later migrations canceled:
PG::UniqueViolation: ERROR:  duplicate key value violates unique constraint "index_users_on_username_lower"
DETAIL:  Key (username_lower)=(walker) already exists.
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rack-mini-profiler-2.3.0/lib/patches/db/pg.rb:110:in `exec'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rack-mini-profiler-2.3.0/lib/patches/db/pg.rb:110:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/connection_adapters/postgresql/database_statements.rb:92:in `block (2 levels) in execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/connection_adapters/postgresql/database_statements.rb:91:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract_adapter.rb:722:in `block (2 levels) in log'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract_adapter.rb:721:in `block in log'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract_adapter.rb:712:in `log'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/connection_adapters/postgresql/database_statements.rb:90:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:890:in `block in method_missing'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:858:in `block in say_with_time'
/usr/local/lib/ruby/2.7.0/benchmark.rb:293:in `measure'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:858:in `say_with_time'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:879:in `method_missing'
/var/www/discourse/db/migrate/20210120125607_rename_english_locale.rb:17:in `rename_locale'
/var/www/discourse/db/migrate/20210120125607_rename_english_locale.rb:6:in `up'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:831:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:9:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:812:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:811:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:471:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:810:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:1002:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:1310:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:1361:in `block in ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/transaction.rb:280:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/transaction.rb:278:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/transactions.rb:212:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:1361:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:1309:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:1281:in `block in migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:1280:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:1280:in `migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:1229:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:1382:in `with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:1229:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:1061:in `up'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/migration.rb:1036:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/tasks/database_tasks.rb:238:in `migrate'
/var/www/discourse/lib/tasks/db.rake:184:in `block (2 levels) in <main>'
/var/www/discourse/lib/tasks/db.rake:148:in `block (3 levels) in execute_concurently'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rails_multisite-2.5.0/lib/rails_multisite/connection_management.rb:76:in `with_connection'
/var/www/discourse/lib/tasks/db.rake:146:in `block (2 levels) in execute_concurently'
Multisite migrator is running using 1 threads
Migrating default
== 20210120125607 RenameEnglishLocale: migrating ==============================
-- execute("UPDATE users\nSET locale = 'en_GB'\nWHERE locale = 'en'\n")
   -> 0.0701s
-- execute("UPDATE site_settings\nSET value = 'en_GB'\nWHERE name = 'default_locale' AND value = 'en'\n")
   -> 0.0009s
-- execute("UPDATE translation_overrides\nSET locale = 'en_GB'\nWHERE locale = 'en'\n")
   -> 0.0006s
-- execute("UPDATE theme_translation_overrides\nSET locale = 'en_GB'\nWHERE locale = 'en'\n")
   -> 0.0006s
-- execute("UPDATE users\nSET locale = 'en'\nWHERE locale = 'en_US'\n")
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:178:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:82:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.5.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:59:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.0.3.3/lib/rails/commands/runner/runner_command.rb:42:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.1.0/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.1.0/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.1.0/lib/thor.rb:392:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.0.3.3/lib/rails/command/base.rb:69:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.0.3.3/lib/rails/command.rb:46:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.0.3.3/lib/rails/commands.rb:18:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.5.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.5.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.5.1/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.5.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.5.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/dependencies.rb:324:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/dependencies.rb:291:in `load_dependency'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/dependencies.rb:324:in `require'
bin/rails:17:in `<main>'
Spinning up 9 Unicorn worker(s) that were stopped initially
I suspect this is due to the PostgresSQL13 update? The PostgresSQL 13 Update announcement says I would need 2x database size, which my server does not have (it is currently at 53% of its disk space). I am not certain what the cause of the issue is so I am not sure how to seek help. I would much appreciate some pointers!
