Did you read about the meaning of those?
Have read through those now, havenāt yet figured out how to change update settings for stable vs. main / beta / or tests-passed.
Edit: Could be the answer is there isnāt a setting for this, maybe dev updates can only be done manually or something? Am just guessing donāt know.
Side note:
During rebuild have notice that:
110:M 11 Feb 2024 04:26:05.828 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
Not sure how to do this, how is this done does anyone know?:
Getting folks to Join up and be active is often a challenge. You need to seed content & discussions. Friends & Family can help. But you may also want to consider promoting your site in other social media platforms.
This is a line in your app.yml
Best to stick with Test-passed. If on Test-passed if you wanted to switch to stable you would need to pause upgrading until stable reaches Test-passed version number. Then edit App.yml to Stable(or what it says in the app.yml comment)
Donāt know how to do that either, what is YML?
Followed those steps to set to stable but may have made a mistake with something, since now when attempting to rebuild again reports:
(<unknown>): could not find expected ':' while scanning a simple key at line 113 column 1 -e LANG=en_US.UTF-8
YAML syntax error. Please check your containers/*.yml config files.
Discourse Doctor reports that same error again and:
starting up existing container
+ /usr/bin/docker start app
Error response from daemon: driver failed programming external connectivity on endpoint app (f3856e49bfe229cf43f040aca909076ea3dadd512282ec333ae67122d327e638): Error starting userland proxy: listen tcp4 0.0.0.0:443: bind: address already in use
Error: failed to start containers: app
Failed to restart the container.
Darn, maybe would be a good idea to start over with this one.
Yup, you have. But this is a trivial issue. Just fix your syntax.
Am not sure what all is proper syntax, is there a way to reset to default or something?
Another report:
(<unknown>): block sequence entries are not allowed in this context at line 18 column 39 -e LANG=en_US.UTF-8
Edit: seems to be corrected now rebuild is working.
Set one site to stable updates will set other one to main recent developer updates.
I think this has strayed quite far beyond the original question. Letās close this off now itās solved and you can start a new topic on installing a stable version. ![]()
