I upgrade regularly (every month or so), and haven’t had an issue like this that prevented building. My server is currently inaccessible.
I would say I have a pretty standard install. There is ample free disk space. discourse-doctor didn’t produce any errors or things that looked suspicious. Nothing about the system has changed. A git pull was performed before attempting launcher rebuild app. If more info is needed for a proper diagnosis, let me know. I’m not quite sure from the log what the issue is. If someone more familiar with this software can take a look, I’d appreciate it.
Here are the plugins I’m using:
- git clone https://github.com/discourse/discourse-akismet.git
- git clone https://github.com/discourse/discourse-spoiler-alert.git
- git clone https://github.com/discourse/discourse-yearly-review.git
- git clone https://github.com/discourse/discourse-patreon
- git clone https://github.com/discourse/discourse-solved
- git clone https://github.com/discourse/discourse-github
- git clone https://github.com/discourse/discourse-checklist
- git clone https://github.com/discourse/discourse-tooltips.git
- git clone https://github.com/discourse/discourse-docs
- git clone https://github.com/discourse/discourse-user-notes
- git clone https://github.com/discourse/discourse-math
- git clone https://github.com/discourse/discourse-chat-integration
- git clone https://github.com/discourse/discourse-encrypt.git
- git clone https://github.com/discourse/discourse-footnote
- git clone https://github.com/discourse/discourse-follow
- git clone https://github.com/discourse/discourse-push-notifications
Here is the end of my build log:
I, [2022-10-12T15:47:04.673293 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2022-10-12T15:47:09.943126 #1] INFO -- : discourse-math is already at latest compatible version
discourse-chat-integration is already at latest compatible version
discourse-spoiler-alert is already at latest compatible version
discourse-encrypt is already at latest compatible version
discourse-tooltips is already at latest compatible version
discourse-follow is already at latest compatible version
docker_manager is already at latest compatible version
discourse-github is already at latest compatible version
discourse-push-notifications is already at latest compatible version
discourse-solved is already at latest compatible version
discourse-akismet is already at latest compatible version
discourse-footnote is already at latest compatible version
discourse-yearly-review is already at latest compatible version
discourse-checklist is already at latest compatible version
discourse-patreon is already at latest compatible version
discourse-docs is already at latest compatible version
discourse-user-notes is already at latest compatible version
I, [2022-10-12T15:47:09.944907 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
I, [2022-10-12T15:47:23.023114 #1] INFO -- : gem install sawyer -v 0.9.2 -i /var/www/discourse/plugins/discourse-github/gems/2.7.6 --no-document --ignore-dependencies --no-user-install
Successfully installed sawyer-0.9.2
1 gem installed
gem install octokit -v 5.6.1 -i /var/www/discourse/plugins/discourse-github/gems/2.7.6 --no-document --ignore-dependencies --no-user-install
Successfully installed octokit-5.6.1
1 gem installed
I, [2022-10-12T15:47:23.024237 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
103:M 12 Oct 2022 15:47:34.098 * 100 changes in 300 seconds. Saving...
103:M 12 Oct 2022 15:47:34.102 * Background saving started by pid 1695
1695:C 12 Oct 2022 15:47:34.384 * DB saved on disk
1695:C 12 Oct 2022 15:47:34.386 * RDB: 0 MB of memory used by copy-on-write
103:M 12 Oct 2022 15:47:34.407 * Background saving terminated with success
- Building
- Building
- building...
Though the "loose" option was set to "false" in your @babel/preset-env config, it will not be used for @babel/plugin-proposal-private-property-in-object since the "loose" mode option was set to "true" for @babel/plugin-proposal-class-properties.
The "loose" option must be the same for @babel/plugin-proposal-class-properties, @babel/plugin-proposal-private-methods and @babel/plugin-proposal-private-property-in-object (when they are enabled): you can silence this warning by explicitly adding
["@babel/plugin-proposal-private-property-in-object", { "loose": true }]
to the "plugins" section of your Babel config.
Though the "loose" option was set to "false" in your @babel/preset-env config, it will not be used for @babel/plugin-proposal-private-methods since the "loose" mode option was set to "true" for @babel/plugin-proposal-private-property-in-object.
["@babel/plugin-proposal-private-methods", { "loose": true }]
[WARN] (broccoli-terser-sourcemap) Minifying "assets/discourse.js" took: 26102ms (more than 20,000ms)
Killed
error Command failed with exit code 137.
I, [2022-10-12T15:51:18.234000 #1] INFO -- : Checking 'discourse-homepage-feature-component' for 'default'... up to date
Checking 'Versatile Banner' for 'default'... up to date
Checking 'Custom Header Links' for 'default'... yarn run v1.22.19
$ /var/www/discourse/app/assets/javascripts/node_modules/.bin/ember build -prod
Environment: production
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
I, [2022-10-12T15:51:18.245871 #1] INFO -- : Terminating async processes
I, [2022-10-12T15:51:18.246532 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
I, [2022-10-12T15:51:18.247499 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 103
103:signal-handler (1665589878) Received SIGTERM scheduling shutdown...
2022-10-12 15:51:18.249 UTC [42] LOG: received fast shutdown request
103:M 12 Oct 2022 15:51:18.327 # User requested shutdown...
103:M 12 Oct 2022 15:51:18.327 * Saving the final RDB snapshot before exiting.
2022-10-12 15:51:19.052 UTC [42] LOG: aborting any active transactions
2022-10-12 15:51:19.100 UTC [42] LOG: background worker "logical replication launcher" (PID 51) exited with exit code 1
2022-10-12 15:51:19.102 UTC [46] LOG: shutting down
2022-10-12 15:51:19.188 UTC [42] LOG: database system is shut down
103:M 12 Oct 2022 15:51:20.072 * DB saved on disk
103:M 12 Oct 2022 15:51:20.073 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 1601 exit 137>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
bootstrap failed with exit code 137
5354ffedbf56742079333cb69face684193aaa0afa7f1ff492666e17a2e1f51d
