I have now activated sso via WP plugin and in discourse. When I try to link to my forum I get: The webpage at http://pods.myenterpride.com/session/sso has resulted in too many redirects. Clearing your cookies for this site or allowing third-party cookies may fix the problem. If not, it is possibly a server configuration issue and not a problem with your computer.
I can also not get into my admin account via /users/admin-login I am getting [‘BAD CSRF’]
To get back into your site, try to open a private tab to use /users/admin-login.
If this doesn’t work, ssh into your server and use these instructions to manually disable SSO.
I think that your SSO url is wrong. I was redirected to http://pods.myenterpride.com?sso=<token>&sig=<signature>, which is the domain of your Discourse installation. While I have no idea about the WP side of things, this needs to point somewhere where WP handles it.
I’m still intrigued by the BAD CSRF. I literally didn’t do anything than opening a new private tab in chrome, put in your E-Mail address, submitted the form, and got a confirmation…
Your situation sounds very complex. You may need to wait until business weekdays for us to help. We generally do not work weekends unless something is on fire.
Thank you all for your input, I have solved the problem For those that may follow this thread, and are trying to connect discourse to a WP multisite here is what you shouldn’t and should do.
Don’t use WP Multisite SSO plugin, it breaks everything. Use WP Multisite User Management instead. @AdamCapriola Sorry mate, I couldn’t get your plugin to work, probably my lack of coding experience, though.
What worked: On the WP side: Use the WP Discourse plugin, Check the ‘Enable SSO to Discourse’, check that all user ID’s are the same across the network. On Discourse side: Enable SSO, Enable SSO Provider, and set URL to yoursite.com (for some reason I overlooked this ), override e-mail, override username and set not approved url. Clear all caches and test incognito.
