i know im a couple of months late on this but i finally took the plunge and started my self hosted journey with this new script. I already had a proxmox/ubuntu vm running docker compose so i figured id continue in there. Since this was simply for testing purposes (my site doesnt even exist yet), I did not expect to need anything opened in my firewall. But as many of you probably already know, the sub-domain verification will fail if you dont do anything other than run the wget script.
re running ./discourse-setup --skip-connection-test will at least allow you past but it does not solve the problem…My inexperienced self took a few too many google searches to find someone mentioning this skip method so i just wanted to add that in here in case someone comes across it.
i dont have a proxy setup right now but what is the best method to properly setup my discourse server so i dont lose my domain and can continue testing until im ready to expose it to my audience? do i need to get my butt in gear and get the proxy setup? or is there another method to safely open 443/80?
