Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' נכשל עם החזרה
סיכום מבוסס בינה מלאכותית
Summary
Ratnam_Raju_Varsala encountered an error when running ./launcher rebuild app after adding a plugin to their Discourse app. The error message indicated a Pups::ExecError with a failed su postgres command.
Heliosurge suggested trying safe mode, but Ratnam_Raju_Varsala reported that the site was completely down and safe mode was not working.
Heliosurge asked Ratnam_Raju_Varsala to post the $plugins section of their app.yml file, but Ratnam_Raju_Varsala reported that they had removed the plugin.
Heliosurge suggested that there might be a formatting error in the app.yml file and asked Ratnam_Raju_Varsala to post the file contents between [code] tags.
Ratnam_Raju_Varsala posted the error message again, which indicated that the data directory had invalid permissions.
Heliosurge suggested running discourse-doctor to diagnose the problem and recommended regular backups.
Canapin asked Ratnam_Raju_Varsala to provide context and explain what they were trying to achieve.
Pfaffman identified the problem as a permissions issue with the Postgres data directory.
Ratnam_Raju_Varsala reported that they had solved the issue by changing the Postgres data permissions.
Heliosurge congratulated Ratnam_Raju_Varsala on solving the issue and recommended exploring other plugins.
Iam getting following error when i tried run ./launcher rebuild app
FAILED
Pups::ExecError: su postgres -c ‘psql discourse -c “alter schema public owner to discourse;”’ failed with return #<Process::Status: pid 54 exit 2>
Location of failure: /usr/local/lib/ruby/gems/3.1.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn’
exec failed with the params “su postgres -c ‘psql $db_name -c "alter schema public owner to $db_user;"’”
bootstrap failed with exit code 2
4079c40b96373f2f33049a30414bc383acf909fc3863bdb52a1a678a9f0cc9f7
Originally sent in general
Ratnam_Raju_Varsala
Hi @Canapin, how can i integrate plugins into docker app ?
Heliosurge
Ratnam_Raju_Varsala
FAILED
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return #<Process::Status: pid 54 exit 2>
Location of failure: /usr/local/lib/ruby/gems/3.1.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params "su postgres -c 'psql $db_name -c "alter schema public owner to $db_user;"'"
root@community-online:/var/discourse# /discourse-doctor
-bash: /discourse-doctor: No such file or directory
iam getting this error after adding plugin in app.yml file
Heliosurge
can you post that section of your app.yml where you added plugin under docker?
You have to ensure the formatting is pretty precise.
it is a bit of a pain but usually only install snd rebuild 2 plugin at a time
What plugin are you trying to install?
Ratnam_Raju_Varsala
The site was working fine until the plugin was added, after adding this error, the site is down
Heliosurge
Delete part of your chat post. You have sensitive info. only need the section whhere it ssys $home type stuff abd plugin info.
You have your trade buttons plugins added twice. Remove noth instances and try a rebuild abd see if site is restored
Only need from here down if chat allows wrap it with something like ´´ .... ´´
Ratnam_Raju_Varsala
no not added twise
just i paste here after completion app.yml content
JammyDodger
I think this would probably be better discussed in the topic. I'll move these messages over. :+1:
Ratnam_Raju_Varsala
deleted
Heliosurge
cool jam. can you remove his sensitive info so just plugin info?
I, [2023-02-11T18:58:30.914906 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2023-02-11T18:58:30.917342 #1]  INFO -- :
I, [2023-02-11T18:58:30.917415 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2023-02-11T18:58:30.930655 #1]  INFO -- :
I, [2023-02-11T18:58:30.930872 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2023-02-11T18:58:30.933165 #1]  INFO -- :
I, [2023-02-11T18:58:30.933384 #1]  INFO -- : > /root/upgrade_postgres
I, [2023-02-11T18:58:30.937415 #1]  INFO -- :
I, [2023-02-11T18:58:30.937665 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2023-02-11T18:58:30.939673 #1]  INFO -- :
I, [2023-02-11T18:58:30.940012 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2023-02-11T18:58:30.940639 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2023-02-11T18:58:30.941061 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2023-02-11T18:58:30.941491 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2023-02-11T18:58:30.941859 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2023-02-11T18:58:30.942208 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2023-02-11T18:58:30.942546 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2023-02-11T18:58:30.945002 #1]  INFO -- :
I, [2023-02-11T18:58:30.945405 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2023-02-11T18:58:30.945805 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2023-02-11T18:58:30.946227 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2023-02-11T18:58:30.946605 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2023-02-11T18:58:30.946992 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-02-11T18:58:30.947317 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-02-11T18:58:30.947660 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2023-02-11T18:58:30.949060 #1]  INFO -- : > sleep 5
2023-02-11 18:58:30.959 UTC [42] FATAL:  data directory "/shared/postgres_data" has invalid permissions
2023-02-11 18:58:30.959 UTC [42] DETAIL:  Permissions should be u=rwx (0700) or u=rwx,g=rx (0750).
I, [2023-02-11T18:58:35.952167 #1]  INFO -- :
I, [2023-02-11T18:58:35.952437 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
createdb: error: could not connect to database template1: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: No such file or directory
	Is the server running locally and accepting connections on that socket?
I, [2023-02-11T18:58:35.994953 #1]  INFO -- :
I, [2023-02-11T18:58:35.995243 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
psql: error: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: No such file or directory
I, [2023-02-11T18:58:36.036721 #1]  INFO -- :
I, [2023-02-11T18:58:36.037043 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2023-02-11T18:58:36.078384 #1]  INFO -- :
I, [2023-02-11T18:58:36.078703 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2023-02-11T18:58:36.120285 #1]  INFO -- :
I, [2023-02-11T18:58:36.120682 #1]  INFO -- : Terminating async processes
FAILED
exec failed with the params "su postgres -c 'psql $db_name -c \"alter schema public owner to $db_user;\"'"
4c2225e9c667f9fc2b7b4f9bd26c03f243e877b123be1d41a3c57bf90c049595
When you add a plugin you will want to copy abd position the code like the one above. I believe no spaces between lines.
Also verify the plugin you want to use is still supported.
can you post that plugin link? not familar eith that one iff hand. better if it has a link here in discourse as well.
discourse git clone GitHub - jannolii/discourse-topic-trade-buttons · GitHub
I removed plugin and after that try to rebuild it, but after removing the plugin iam getting this error, before its working fine.
I, [2023-02-11T18:58:30.949060 #1] INFO – : > sleep 5
2023-02-11 18:58:30.959 UTC [42] FATAL: data directory “/shared/postgres_data” has invalid permissions
I, [2023-02-11T18:58:35.952167 #1] INFO – :
I, [2023-02-11T18:58:35.952437 #1] INFO – : > su postgres -c ‘createdb discourse’ || true
createdb: error: could not connect to database template1: connection to server on socket “/var/run/postgresql/.s.PGSQL.5432” failed: No such file or directory
I, [2023-02-11T18:58:35.994953 #1] INFO – :
I, [2023-02-11T18:58:35.995243 #1] INFO – : > su postgres -c ‘psql discourse -c “create user discourse;”’ || true
psql: error: connection to server on socket “/var/run/postgresql/.s.PGSQL.5432” failed: No such file or directory
I, [2023-02-11T18:58:36.036721 #1] INFO – :
I, [2023-02-11T18:58:36.037043 #1] INFO – : > su postgres -c ‘psql discourse -c “grant all privileges on database discourse to discourse;”’ || true
I, [2023-02-11T18:58:36.078384 #1] INFO – :
I, [2023-02-11T18:58:36.078703 #1] INFO – : > su postgres -c ‘psql discourse -c “alter schema public owner to discourse;”’
I, [2023-02-11T18:58:36.120285 #1] INFO – :
I, [2023-02-11T18:58:36.120682 #1] INFO – : Terminating async processes
FAILED
I am nnot fully sure of the procedure but you might be able to load the site in safe mode.
@JammyDodger can you link the procedure for safe mode?
Have you seen my log file?
As you can see, “safe mode” is automatically converted into a link to the safe mode tutorial :slight_smile:
Awesome thank you. my spologies. canapin do you see something that might be causing this issue? at a guess maybe a formatting usdye in app.yml?
excerpt from safe mode topic.
2023-02-11 19:20:40.842 UTC [42] FATAL: data directory “/shared/postgres_data” has invalid permissions
2023-02-11 19:20:40.842 UTC [42] DETAIL: Permissions should be u=rwx (0700) or u=rwx,g=rx (0750).
I, [2023-02-11T19:20:45.834611 #1] INFO – :
I, [2023-02-11T19:20:45.834887 #1] INFO – : > su postgres -c ‘createdb discourse’ || true
ypu may need to scroll up higher. Have you triedvthe safe mode procedure?
Not sure if it will work in this case or not tbh.
Site completely down, even i added safemode its not working, site down app not running
Can you repost the $plugins goes here section of your app.yml?
just be sure to pist it inside of “code” ending with “/code” replace quotes with “[” “]”
Your app.yml cintent here
- does nor trigger markdown
Dan, i removed plugin from app.yml file, there is no plugin now, but i will post you here again
volumes:
  • volume:
    guest: /shared
  • volume:
    guest: /var/log
Plugins go here
see Install plugins on a self-hosted site for details
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- git clone GitHub - discourse/docker_manager: Plugin for use with discourse docker image · GitHub
I understand that but you may have a formatting error. The app.yml file us very picky…just one line outbof alignment can cause problems.
This why I mentioned pasting inbetween the code markdown so we can see a raw version of your file.
Something even simple as an empty line between lines can cause a problem.
