I see the “is_accepted_answer” name with the “true” value in the post_custom_fields. I also see the created_at and updated_at field but I am looking for something like an updated_by field. Where can I find out who marked the post as the solution?
סיכום מבוסס בינה מלאכותית
wildrobo is trying to find out who marked a post as the solution. david suggests using Data Explorer queries, providing links to relevant topics with example queries. wildrobo tries the queries but doesn’t get any results for action_type = 15. david explains that logging for the “solved” event was only added to the plugin 6 months ago, so older events may not be accurate. wildrobo confirms that the topics involved are only a couple of days old, but suspects that their plugin version (“0.1”) may not include the necessary update to track the “solved” event.
There’s some queries you can put into data explorer here:
I’ve also just added them to the main discourse-solved topic, alongside the “badges” SQL queries
Thanks for the super detailed response. I took a look and don’t have any results for action_type = 15. Is that the same as post_action_type? Looks like I have only 8.
How old are the “solved” events that you’re trying to analyse, it’s possible that you’ve hit this problem
Thanks. The topics involved and the “solved” events are only a couple of days old. I will check to see the versions. You have definitely given me things to check out.
It looks like there is only 1 version “0.1” of the plugin and I appear to be on that version. My guess is the update with the “solved” event does not exist in what I am running.
