How to know who opted the Solution
The discussion revolves around identifying who marked a post as the solution in a Discourse forum. Ravindra-Trdx asks how to determine who selected a post as ‘Solved’. Moin suggests using the Data Explorer plugin and references a feature request to display the user who marked the solution. Aaron_Walsh shares a theme component that visually indicates the solver and their solved topics. Moin clarifies that the goal is to find who decided the solution, not just the author. Aaron_Walsh acknowledges the misunderstanding. nat provides an update: the feature to show who marked a topic as solved is now available, with a site setting to enable it, and examples are visible on the meta site.
Right now it shows which user post has been selected as Solved “Solved By”.
How to know who actually has opted it as Solution and clicked on Solved?
You can use the data explorer plugin to find out
There’s also this open Contribute > Feature request you may find interesting and want to add your voice to:
Thank you
It worked
This may help; I use it myself. Theme component from @Don.
How does that component help to find out who clicked the solution button below the post to mark the topic as solved?
I have set it with red for unsolved and green as solved, including the solved avatar who solved the topic.
Plus, you can find by clicking the profile’s. solved icon, which brings up all other topics.
This topic is not about finding out who is the author of the post that is marked as the solution. But about who decided that it is the solution.
I don’t think that information is shown in the profile. Or can you tell me who decided that post 2 is the solution?
Sorry, my bad. I misread the message. :face_in_clouds: :tired_face:
Lifting this from the feature topic:
