Questions about moderator shield badge
סיכום מבוסס בינה מלאכותית
The discussion revolves around customizing title badges for different user groups on a Discourse platform. maniacalmorgan wants to differentiate between admin and moderator badges, as well as create a custom badge for VIP users.
HAWK and MakaryGo suggest using CSS to customize the badges. MakaryGo also mentions that adding a similar icon to a specific user group can be achieved using CSS.
Regarding assigning users to a user group through the company’s back end, MakaryGo and maniacalmorgan discuss the possibility of using the Discourse API to achieve this. MakaryGo points out that the full documentation on API functions can be found on the Discourse website.
Additionally, MakaryGo suggests using built-in group flair on user avatars to visually distinguish between groups. This can be set up in the group settings, as explained by MakaryGo and simon. However, BurtHerman and simon discuss the limitations of editing group settings for default groups, and simon provides a link to a guide on creating a custom group with associated flair.
I poked around, but couldn’t find the right answers to my questions.
I see that you can edit the title badges, but I haven’t quite figured out how. As an example, both admins and moderators have the shield icon next to their name. I haven’t been able to locate where this association lives within the settings. I would like admins and moderators to have different badges since for us admins are staff while moderators are not.
Second use case might be answered by the above, but we will be introducing VIP users and as such, would like to give them a custom title badge. Is there a way to automate this? I’m not on the development side, but our discourse is connected to our platform’s back end in some way. Would it be as simple as associating a title badge with a user group and then using our back end to apply that group to all the users meeting the VIP condition?
Edit: As an edit, I’m a business user. Not sure if that changes my available options/preferences.
Those are the default indicators of moderators and there isn’t actually a setting to change it, although you could use CSS I imagine.
4 לייקים
And the second question - is there a way to add a similar icon to a specific user group?
Yup, using css. All posts have group class attached to it.
לייק 1
Great! I had assumed so based on what I read, but just wanted to check. Now, do you know if the API would allow for us to assign users to a usergroup through our back end?
I’m a bit confused. Do you want to assign users to a group via API or via backend? Or do you have in mind any custom backend? (Still, I believe that in any case an answer is Yes)
Through our back end, not Discourse back end. Sorry for the confusion. I’m on the marketing team, so the technical stuff is a little beyond me.
We’d want to change assign a user group to specific users through our company’s back end. Essentially, we’re trying to create a VIP program where users who spend $X with us become VIP. One of the perks we’re looking at is a title badge. The last question is so that we can aggregate all the users meeting that critera on our side and use the API to move them into the VIP user group. Hope that makes sense.
You most definitely can. Full documentation on all API functions can be found here. Also, if you want to distinguish visually group of customers, wouldn’t it be easier (and more fun! :wink: ) to use built-in option to display a group flair on user avatar (as you can see on @HAWK’s example)? image
Cheers!
לייק 1
Yes! That would be neat and would work to designate staff over moderators too. Is that built into the options, or does it need to be done through CSS?
Its built in :smiling_face: You just have to set it in the group settings (either as Font Awesome glyph or as your own picture), and check ‘set this as default user group’
4 לייקים
Can you set group settings on an existing group? I don’t see how to get to the settings once a group is already created, just the options when you create a new group
Yes, go to the group’s page and click the Manage link:
2 לייקים
But these are the only options I see below - seems it doesn’t work to edit the groups that are created by default:
RIght, if you are trying to add an avatar flair to a group, you will need to create a custom group. That’s how we set the team avatar flair on Meta. Have a look at Create a group that automatically adds associated flair to its members’ avatars for details about setting it up.
4 לייקים
