Quick Messages Plugin
http://forum.kozovod.com - my nickname is meg. After signing up, you can switch to English in your profile settings.
I can easily reproduce the issue - it actually happens every time I talk with someone in pvt. NOTE: I’m using the standard private messages, not responding through your plugin.
UPD. Also, I just discovered that it shows (1) in a green circle as soon as I write a message to someone without using your plugin. This is also an issue that should be fixed.
Please change my tl so I can send messages.
username: Angus_McLeod
Done for Angus_McLeod
לייק 1
I’ve committed a number of fixes for unread state coming out of our testing. Please rebuild with the latest on this plugin and let’s test again.
https://github.com/angusmcleod/discourse-quick-messages/commit/77e8b2fd73a8fd39f457f7dfaf39b046e436dbe7
https://github.com/angusmcleod/discourse-quick-messages/commit/831448ad1b17462f8ce9249f430f17cf60d8fbf2
3 לייקים
Thanks.
Still a “green one” appears immediately when I post a message to someone!
Ok, made another change for that specific issue. There were a number of issues with count to fix. Please try again.
לייק 1
@angus I just installed this plugin, but When I received a message from default system user, it didn’t show that message in this plugin. Is it a bug?
The issue now is that there is often NO counter displayed in the green box when it should be.
Hey @john3. What kind of message is it? Is it an automated message or a message composed by a real person?
Just to keep track of updates, I still don’t get any green circle notifications when new PM is sent to me… :frowning:
Yes, my apologies, I will get to this as soon as I can. Over the weekend I was working on full page chat for babble which required all of my attention. Many balls in the air at the moment.
2 לייקים
Ok Angus, We really enjoy your plugin here in France!
Installed yesterday, works fine!
Well I noticed some bugs or improvements. Please consider our feedback.
  1. Emojis don’t work in direct message box. Grey Screen here:
  2. Hide/Show the direct message box = Close the direct message box
  3. Create a new conversation with a new user (never speak to him before) need to begin with a message of minimun 20 characters (depends of configuration, but you see what i mean…) All responses after that don’t have to respect this 20 characters limitation (that’s OK!).
  4. In the Top Direct Message Menu,
  5. long post names are cropped, maybe we could use two lines or resize the top menu box?
  6. cause of French translation or I don’t know, “Create New Message” text is cropped
sorry for the long feeback and Gif abuse…
2 לייקים
@Sly_Do Thanks for the feedback!
This is fixed.
https://github.com/angusmcleod/discourse-quick-messages/commit/c33294daaa161b553ea7aa428650c6f24238555c
This is intentional. If there is no content in the compose input (as in your gif), hide = close. This is the same as the normal Discourse compose. If there is content in the compose input hide = minimize
This is fixed.
https://github.com/angusmcleod/discourse-quick-messages/commit/a1f8d20d19eb12b4c442a13b6357a6ee39c11033
@meglio Looking at the unread count issue again now.
2 לייקים
This should work now. After struggling with it for a while, I’ve reverted to using the built in unread_private_messages count generated by discourse core. The message count will be the same as what you would normally see in vanilla discourse minus messages that are not user to user.
This is fixed.
https://github.com/angusmcleod/discourse-quick-messages/commit/8c1cc419525bf4523cf33e5232960ea25f0ac253
2 לייקים
This plugin is now up to date with Ember 2.4 (see further here).
https://github.com/angusmcleod/discourse-quick-messages/commit/75119fb7b8d12a634fc71d0fe5f89c7fa1812be2
3 לייקים
@angus I just updated, and my site crashed. after disabling this plugin its working fine again. please check the issue.
P.s: the version I am using is: 1.6.8
@john3 Are you sure it’s this plugin? Running both locally and in docker on a live server on the latest version I’m not seeing issues. If the issue persists, please send me some logs so I can figure out why it’s happening in your case.
@angus ummm I had 3 plugins installed, Babble, quick message and spoiler. So I uninstalled all. site worked. then I installed Babble, site worked. then I installed message plugin site was again blank with background color of my forum. So hence I uninstalled the quick message plugin again, and site worked fine.
Ok. Can you send me the logs you get when you install Quick Messages and the site doesn’t work? Thanks.
Hi, I faced the same issue, disabling quick message solved the problem.
Unfortunately, I forgot to capture the log since my site needs to back to work asap.
The recent commits causes this problem since I use Quick Message for some time already.
