La tâche Rake "assets:precompile" échoue en raison d'un problème de compilation JS
J’essaie de faire une nouvelle installation pour Discourse et je vois l’erreur ci-dessous lors de l’exécution de la tâche assets:precompile. Je vois l’erreur de compilation ci-dessous mais je ne suis pas sûr de ce qu’elle signifie.
rake aborted!
Barber::PrecompilerError: Pre compilation failed for: {{#if isActive}}
  {{!-- template-lint-disable no-invalid-interactive --}}
  <div {{on "keydown" (action "keydown")}} class="emoji-picker {{if @isActive "opened"}}">
    {{!-- template-lint-enable no-invalid-interactive --}}
    <div class="emoji-picker-category-buttons">
      {{#if recentEmojis.length}}
        <button type="button" data-section="recent" {{action "onCategorySelection" "recent"}} class="btn btn-default category-button emoji">
          {{replace-emoji ":star:"}}
        </button>
      {{/if}}
      {{emoji-group-buttons onCategorySelection=(action "onCategorySelection") tagName=""}}
      {{#each-in customEmojis as |group emojis|}}
        <button type="button" data-section={{concat "custom-" group}} {{action "onCategorySelection" (concat "custom-" group)}} class="btn btn-default category-button emoji">
          {{replace-emoji (concat ":" emojis.firstObject.code ":")}}
        </button>
      {{/each-in}}
    </div>
    <div class="emoji-picker-content">
      <div class="emoji-picker-search-container">
        {{input
          class="filter"
          name="filter"
          placeholder=(i18n "emoji_picker.filter_placeholder")
          autocomplete="discourse"
          autocorrect="off"
          autocapitalize="off"
          input=(action "onFilter")
        {{d-icon "search"}}
      </div>
      <div class="emoji-picker-emoji-area" role="button" {{on "click" this.onEmojiSelection}} {{on "mouseover" this.onEmojiHover}}>
        <div class="results"></div>
        {{#conditional-loading-spinner condition=isLoading}}
          <div class="emojis-container">
              <div class="section recent" data-section="recent">
                <div class="section-header">
                  <span class="title">{{i18n "emoji_picker.recent"}}</span>
                  {{d-button icon="trash-alt" action=(action "onClearRecents") class="trash-recent"}}
                </div>
                <div class="section-group">
                  {{#each recentEmojis as |emoji|}}
                    {{replace-emoji (concat ":" emoji ":") (hash lazy=true)}}
                  {{/each}}
                </div>
              </div>
            {{/if}}
            {{emoji-group-sections}}
              <div class="section" data-section="custom-{{group}}">
                    {{i18n (concat "emoji_picker." group)}}
                  </span>
                </div>
                {{#if emojis.length}}
                    {{#each emojis as |emoji|}}
                      <img title={{emoji.code}} width="20" height="20" loading="lazy" class="emoji" src={{emoji.src}}>
                    {{/each}}
                  </div>
                {{/if}}
              </div>
            {{/each-in}}
          </div>
        {{/conditional-loading-spinner}}
      </div>
      <div class="emoji-picker-footer">
        <div class="emoji-picker-emoji-info">
          {{#if hoveredEmoji}}
            {{replace-emoji (concat ":" hoveredEmoji ":")}}
          {{/if}}
        </div>
        <div class="emoji-picker-diversity-picker">
          {{#each diversityScales as |diversityScale index|}}
            {{d-button
              icon=diversityScale.icon
              class=(concat "diversity-scale " diversityScale.name)
              title=diversityScale.title
              action=(action "onDiversitySelection" index)
          {{/each}}
        </div>
      </div>
    </div>
  </div>
  {{#if site.mobileView}}
    <div role="button" class="emoji-picker-modal-overlay" {{on "click" this.onClose}}></div>
  {{/if}}
{{/if}}
. Le compilateur a dit : Error
~/Discourse/Discourse-2.8.x/AL2_x86_64/DEV.STD.PTHREAD/build/private/env/ruby2.7.x/ruby2.7.x/lib/ruby/gems/2.7.0/gems/barber-0.12.2/lib/barber/precompiler.rb:33:in `rescue in compile'
~/Discourse/Discourse-2.8.x/AL2_x86_64/DEV.STD.PTHREAD/build/private/env/ruby2.7.x/ruby2.7.x/lib/ruby/gems/2.7.0/gems/barber-0.12.2/lib/barber/precompiler.rb:30:in `compile'
~/Discourse/Discourse-2.8.x/AL2_x86_64/DEV.STD.PTHREAD/build/private/env/ruby2.7.x/ruby2.7.x/lib/ruby/gems/2.7.0/gems/barber-0.12.2/lib/barber/precompiler.rb:8:in `compile'
~/Discourse/Discourse-2.8.x/AL2_x86_64/DEV.STD.PTHREAD/build/private/env/ruby2.7.x/ruby2.7.x/lib/ruby/gems/2.7.0/gems/ember-handlebars-template-0.8.0/lib/ember/handlebars/template.rb:166:in `block in precompile_ember_handlebars'
~/Discourse/Discourse-2.8.x/AL2_x86_64/DEV.STD.PTHREAD/build/private/env/ruby2.7.x/ruby2.7.x/lib/ruby/gems/2.7.0/gems/sprockets-3.7.2/lib/sprockets/cache.rb:85:in `fetch'
~/Discourse/Discourse-2.8.x/AL2_x86_64/DEV.STD.PTHREAD/build/private/env/ruby2.7.x/ruby2.7.x/lib/ruby/gems/2.7.0/gems/ember-handlebars-template-0.8.0/lib/ember/handlebars/template.rb:165:in `precompile_ember_handlebars'
~/Discourse/Discourse-2.8.x/AL2_x86_64/DEV.STD.PTHREAD/build/rails-root/lib/freedom_patches/raw_handlebars.rb:99:in `call'
Cela ne ressemble pas à une installation standard ?
oui, j’essaie de faire une installation personnalisée sur une machine Amazon Linux
Bien que Discourse soit un logiciel libre et open source, ici sur Meta, nous limitons notre support gratuit aux installations qui suivent le guide d’installation standard. Comme il existe une infinité de combinaisons de façons d’exécuter le logiciel, cela nous permet de fournir une base facile à utiliser et toujours à jour pour tous les utilisateurs.
Si vous cherchez à personnaliser Discourse, en utilisant des plugins ou des thèmes, vous pouvez tout changer tout en exécutant une installation prise en charge.
Et si, au lieu de cela, vous apportez des modifications en créant une “fork”, vous regretterez amèrement de l’avoir fait.
J’ai pu identifier la cause première du problème. Essentiellement, lors de l’exécution de la tâche rake assets-precompile, le système essaie de charger tous les fichiers js en utilisant les modèles hbs dans emoji-picker.hbs. Le modèle contient certaines variables qui nécessitent que les données soient fournies par l’appelant, et c’est là que l’analyse échoue. Les autres fichiers hbs qui n’ont pas de référence ‘@’ sont compilés avec succès.
Avez-vous des idées ou de la documentation sur la façon dont ces modèles hbs sont utilisés dans Discourse ?
Vous pourriez commencer par Guide du débutant pour la création de plugins Discourse Partie 1 : Création d’un plugin de base.
