Problema di aggiornamento
Non sono riuscito a eseguire un backup su Discourse. La pagina web di aggiornamento diceva che c’era una versione più recente, ma non si aggiornava perché la pagina effettiva dopo la pagina di aggiornamento diceva che non c’erano aggiornamenti. Quindi, ho finito per fare:
cd /var/discourse
./launcher rebuild app
È andato avanti per molto tempo e poi ho visto questi errori e non sono sicuro di dove andare dopo.
rake aborted!
NoMethodError: undefined method `path' for nil:NilClass
/var/www/discourse/lib/discourse_ip_info.rb:48:in `mmdb_download'
/var/www/discourse/lib/tasks/assets.rake:281:in `block (3 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:281:in `each'
/var/www/discourse/lib/tasks/assets.rake:281:in `block (2 levels) in <main>'
Tasks: TOP => assets:precompile
I, [2023-03-10T02:47:53.924124 #1]  INFO -- : yarn run v1.22.19
$ /var/www/discourse/app/assets/javascripts/node_modules/.bin/ember build -prod
WARNING: Node v18.14.2 is not tested against Ember CLI on your platform. We recommend that you use the most-recent "Active LTS" version of Node.js. See https://git.io/v7S5n for details.
Environment: production
cleaning up...
Built project successfully. Stored in "dist/".
File sizes:
 - dist/assets/activate-account.js: 641 B (323 B gzipped)
 - dist/assets/admin.js: 853.83 KB (137.75 KB gzipped)
 - dist/assets/auto-redirect.js: 207 B (173 B gzipped)
 - dist/assets/browser-detect.js: 1001 B (579 B gzipped)
 - dist/assets/browser-update.js: 3.06 KB (1.4 KB gzipped)
 - dist/assets/chunk.13.3ea54e76d8a870a97956.js: 325.32 KB (99.79 KB gzipped)
 - dist/assets/chunk.143.d0263a9558a16acd6ccf.js: 3.83 KB (1.36 KB gzipped)
 - dist/assets/chunk.178.447d3f0e9dcbd06e6f4b.js: 2.06 KB (1.01 KB gzipped)
 - dist/assets/chunk.682.e020248dda65e1c89c3c.js: 831.77 KB (281.53 KB gzipped)
 - dist/assets/core-tests.js: 2.49 MB (323.2 KB gzipped)
 - dist/assets/discourse.js: 3.1 MB (623.23 KB gzipped)
 - dist/assets/embed-application.js: 1.87 KB (757 B gzipped)
 - dist/assets/google-tag-manager.js: 1.01 KB (558 B gzipped)
 - dist/assets/google-universal-analytics-v3.js: 942 B (499 B gzipped)
 - dist/assets/google-universal-analytics-v4.js: 702 B (349 B gzipped)
 - dist/assets/highlightjs/highlight-test-bundle.min.js: 133.83 KB (42.86 KB gzipped)
 - dist/assets/markdown-it-bundle.js: 129.78 KB (43.63 KB gzipped)
 - dist/assets/onpopstate-handler.js: 265 B (206 B gzipped)
 - dist/assets/plugins/chat.js: 575.33 KB (97.76 KB gzipped)
 - dist/assets/plugins/discourse-details.js: 1.32 KB (674 B gzipped)
 - dist/assets/plugins/discourse-local-dates.js: 34.7 KB (9.34 KB gzipped)
 - dist/assets/plugins/discourse-narrative-bot.js: 1.66 KB (791 B gzipped)
 - dist/assets/plugins/discourse-presence.js: 10.95 KB (2.63 KB gzipped)
 - dist/assets/plugins/docker_manager_admin.js: 36.42 KB (6.96 KB gzipped)
 - dist/assets/plugins/lazy-yt.js: 4.12 KB (1.89 KB gzipped)
 - dist/assets/plugins/poll.js: 56 KB (15.31 KB gzipped)
 - dist/assets/plugins/styleguide.js: 93.27 KB (12.69 KB gzipped)
 - dist/assets/plugins/test/chat_tests.js: 173.71 KB (22.68 KB gzipped)
 - dist/assets/plugins/test/discourse-details_tests.js: 3.94 KB (1.13 KB gzipped)
 - dist/assets/plugins/test/discourse-local-dates_tests.js: 28.71 KB (5.54 KB gzipped)
 - dist/assets/plugins/test/discourse-presence_tests.js: 5.55 KB (1.24 KB gzipped)
 - dist/assets/plugins/test/docker_manager_tests.js: 6.16 KB (1.74 KB gzipped)
 - dist/assets/plugins/test/poll_tests.js: 58.71 KB (8.42 KB gzipped)
 - dist/assets/print-page.js: 118 B (130 B gzipped)
 - dist/assets/scripts/discourse-boot.js: 449 B (312 B gzipped)
 - dist/assets/scripts/discourse-test-listen-boot.js: 99 B (101 B gzipped)
 - dist/assets/scripts/discourse-test-load-dynamic-js.js: 637 B (400 B gzipped)
 - dist/assets/scripts/discourse-test-trigger-ember-cli-boot.js: 110 B (104 B gzipped)
 - dist/assets/scripts/module-shims.js: 944 B (471 B gzipped)
 - dist/assets/scripts/start-app.js: 201 B (174 B gzipped)
 - dist/assets/splash-screen.js: 1.8 KB (690 B gzipped)
 - dist/assets/start-discourse.js: 798 B (462 B gzipped)
 - dist/assets/test-helpers.js: 1.02 MB (148.68 KB gzipped)
 - dist/assets/test-i18n.js: 508.32 KB (119.64 KB gzipped)
 - dist/assets/test-site-settings.js: 9.46 KB (3.67 KB gzipped)
 - dist/assets/vendor.css: 0 B
 - dist/assets/vendor.js: 1.07 MB (295.04 KB gzipped)
 - dist/assets/wizard.js: 113.27 KB (34.56 KB gzipped)
 - dist/javascripts/@json-editor/json-editor/2.6.1/jsoneditor.js: 425.11 KB (79.36 KB gzipped)
 - dist/javascripts/ace.js/1.4.13/ace.js: 363.09 KB (98.66 KB gzipped)
 - dist/javascripts/ace.js/1.4.13/ext-searchbox.js: 11.63 KB (3.49 KB gzipped)
 - dist/javascripts/ace.js/1.4.13/mode-html.js: 59.46 KB (17.82 KB gzipped)
 - dist/javascripts/ace.js/1.4.13/mode-scss.js: 23.47 KB (7.79 KB gzipped)
 - dist/javascripts/ace.js/1.4.13/mode-sql.js: 4.73 KB (1.82 KB gzipped)
 - dist/javascripts/ace.js/1.4.13/mode-yaml.js: 4.97 KB (1.73 KB gzipped)
 - dist/javascripts/ace.js/1.4.13/theme-chaos.js: 3.11 KB (1.01 KB gzipped)
 - dist/javascripts/ace.js/1.4.13/theme-chrome.js: 2.97 KB (1.03 KB gzipped)
 - dist/javascripts/ace.js/1.4.13/worker-html.js: 203.22 KB (46.33 KB gzipped)
 - dist/javascripts/ace/ace.js: 362.06 KB (98.41 KB gzipped)
 - dist/javascripts/ace/ext-searchbox.js: 11.63 KB (3.49 KB gzipped)
 - dist/javascripts/ace/mode-html.js: 59.46 KB (17.82 KB gzipped)
 - dist/javascripts/ace/mode-scss.js: 23.47 KB (7.79 KB gzipped)
 - dist/javascripts/ace/mode-sql.js: 2.16 KB (1009 B gzipped)
 - dist/javascripts/ace/mode-yaml.js: 4.97 KB (1.73 KB gzipped)
 - dist/javascripts/ace/theme-chrome.js: 2.97 KB (1.03 KB gzipped)
 - dist/javascripts/ace/worker-html.js: 203.22 KB (46.33 KB gzipped)
 - dist/javascripts/chart.js/3.5.1/chart.min.js: 183.95 KB (63.67 KB gzipped)
 - dist/javascripts/chartjs-plugin-datalabels/2.0.0/chartjs-plugin-datalabels.min.js: 12.59 KB (5.09 KB gzipped)
 - dist/javascripts/count.js: 1.41 KB (636 B gzipped)
 - dist/javascripts/diffhtml/1.0.0-beta.20/diffhtml.min.js: 26.98 KB (9.88 KB gzipped)
 - dist/javascripts/embed-topics.js: 1.31 KB (630 B gzipped)
 - dist/javascripts/embed.js: 2.41 KB (1010 B gzipped)
 - dist/javascripts/magnific-popup/1.1.0/jquery.magnific-popup.min.js: 19.74 KB (7.18 KB gzipped)
 - dist/javascripts/media-optimization-worker.js: 4.89 KB (1.71 KB gzipped)
 - dist/javascripts/pikaday/1.8.2/pikaday.js: 41.55 KB (9.44 KB gzipped)
 - dist/javascripts/squoosh/mozjpeg_enc.js: 38.12 KB (10.49 KB gzipped)
 - dist/javascripts/squoosh/squoosh_resize.js: 4.42 KB (1.26 KB gzipped)
 - dist/javascripts/workbox/workbox-cacheable-response.dev.js: 6.58 KB (1.73 KB gzipped)
 - dist/javascripts/workbox/workbox-cacheable-response.prod.js: 579 B (345 B gzipped)
 - dist/javascripts/workbox/workbox-core.dev.js: 48.27 KB (11.21 KB gzipped)
 - dist/javascripts/workbox/workbox-core.prod.js: 5.75 KB (2.42 KB gzipped)
 - dist/javascripts/workbox/workbox-expiration.dev.js: 20.83 KB (5.48 KB gzipped)
 - dist/javascripts/workbox/workbox-expiration.prod.js: 2.82 KB (1.22 KB gzipped)
 - dist/javascripts/workbox/workbox-routing.dev.js: 31.54 KB (7.58 KB gzipped)
 - dist/javascripts/workbox/workbox-routing.prod.js: 3.32 KB (1.44 KB gzipped)
 - dist/javascripts/workbox/workbox-strategies.dev.js: 34.65 KB (4.79 KB gzipped)
 - dist/javascripts/workbox/workbox-strategies.prod.js: 4.75 KB (1.16 KB gzipped)
 - dist/javascripts/workbox/workbox-sw.js: 1.3 KB (741 B gzipped)
Done in 123.18s.
Downloading MaxMindDB...
Compressing Javascript and Generating Source Maps
I, [2023-03-10T02:47:53.924439 #1]  INFO -- : Terminating async processes
I, [2023-03-10T02:47:53.924471 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
I, [2023-03-10T02:47:53.924522 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 103
2023-03-10 02:47:53.924 UTC [42] LOG:  received fast shutdown request
103:signal-handler (1678416473) Received SIGTERM scheduling shutdown...
2023-03-10 02:47:53.931 UTC [42] LOG:  aborting any active transactions
2023-03-10 02:47:53.934 UTC [42] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2023-03-10 02:47:53.938 UTC [46] LOG:  shutting down
103:M 10 Mar 2023 02:47:53.972 # User requested shutdown...
103:M 10 Mar 2023 02:47:53.972 * Saving the final RDB snapshot before exiting.
103:M 10 Mar 2023 02:47:54.001 * DB saved on disk
103:M 10 Mar 2023 02:47:54.001 # Redis is now ready to exit, bye bye...
2023-03-10 02:47:54.041 UTC [42] LOG:  database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse &amp;&amp; su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #&lt;Process::Status: pid 1005 exit 1&gt;
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
5115b973666558d470cf5d4548ea7d20e13f03bd084ac50477a7edca2f1a5bc1
root@Discourse-1:/var/discourse#
Continuato in Update from 3.0.0.beta16 to 3.1.0.beta2
