for some reason, we randomly get one person waiting for approval.
when we go to check it, there is nothing to approve.
i am not sure if this is a bug, or just some setting not correct?
You should check in with the other admins or moderators, most likely someone else deals with the review before the other checks it. Or is this not the case?
nope, i am the only one touching it. it just says sometimes there is someone waiting to review, then when i go to see it to approve it, there is nothing there. do you want access to our forum?
