Reconstrucción de la app fallando
Hi,
I installed Discourse in a Ubuntu 18.04.1 LTS VM on our Hyper-V server.
The initial setup works and I get to the point where it is supposed to send the activation email and that failed.
I edited the SMTP settings in app.yml and did a ./launcher rebuild app. This fails with the following error message
/usr/bin/docker: Error response from daemon: error while creating mount source path '/var/discourse/shared/standalone': mkdir /var/discourse: read-only file system.
There does not appear to be a /var/discourse/shared/standalone directory at this point.
Any suggestions?
Thanks,
Charlotte
Is this a standard install of Ubuntu on EXT4? Is there any other software on the VM?
Did you follow the standard install guide?
3 Me gusta
I rebuilt the VM with Ubuntu 16.04.5 LTS and now it is working.
thanks,
Charlotte
3 Me gusta
