In a discussion titled “Pups ExecError while rebuilding” under the Installation category with the tag server-resources, OverseersMight reports a rebuild failure due to a Pups::ExecError with exit code 137, indicating a potential memory issue. JammyDodger suggests the error may stem from insufficient memory and recommends checking for a swap file via free, upgrading RAM, or setting vm.overcommit_memory = 1 in /etc/sysctl.conf—citing advice from Ed_S in another topic. OverseersMight confirms no swap file is configured and plans to investigate setup. JammyDodger provides a link to a How-To guide for creating a swap file: Create a Swapfile for Your Linux Server. The thread focuses on resolving memory-related rebuild failures in Discourse by adding swap or adjusting kernel memory settings.
