בנייה מחדש נכשלה עקב אי-תאימות של gem של ruby
סיכום מבוסס בינה מלאכותית
The discussion revolves around a failed rebuild due to a Ruby gem incompatibility, specifically with sass-embedded-1.60.0 requiring RubyGems version 3.3.22 or higher, while the system had 3.3.20. levitte encountered the issue while using a custom container named polyf and running on Debian Bullseye with Ruby 2.7.0. Ed_S suggested checking the installation process, noting that the Docker container’s Ruby version is what matters. Falco pointed out that Ruby 2.7 is no longer supported and likely resulted from a custom install. levitte resolved the issue by pulling the latest changes, realizing they were on an outdated master branch instead of the current main branch. Ed_S clarified that git pull updates the launcher itself, which is necessary before rebuilding. The issue was ultimately resolved, and levitte confirmed the discourse instance was successfully running.
Note: I called my container containers/polyf.yml
discourse-doctor doesn’t handle that at all…
$ ./launcher rebuild polyf
I, [2023-04-06T09:50:45.464717 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
[DEPRECATED] The `--deployment` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local deployment 'true'`, and stop using this flag
[DEPRECATED] The `--without` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local without 'test development'`, and stop using this flag
Bundler::PathError: The path `/var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/sprockets-f4d3dae71ef2` does not exist.
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/source/path.rb:209:in `load_spec_files'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/source/git.rb:205:in `load_spec_files'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/source/path.rb:107:in `local_specs'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/source/git.rb:172:in `specs'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/lazy_specification.rb:82:in `materialize_for_installation'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/spec_set.rb:195:in `map!'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/spec_set.rb:195:in `specs_for_dependency'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/spec_set.rb:33:in `block in for'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/spec_set.rb:22:in `loop'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/spec_set.rb:22:in `for'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/spec_set.rb:79:in `materialize'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/definition.rb:209:in `missing_specs'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/definition.rb:213:in `missing_specs?'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/installer.rb:255:in `resolve_if_needed'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/installer.rb:82:in `block in run'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/process_lock.rb:12:in `block in lock'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/process_lock.rb:9:in `open'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/process_lock.rb:9:in `lock'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/installer.rb:71:in `run'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/installer.rb:23:in `install'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/cli/install.rb:62:in `run'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/cli.rb:260:in `block in install'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/settings.rb:131:in `temporary'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/cli.rb:259:in `install'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/cli.rb:34:in `dispatch'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/cli.rb:28:in `start'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/exe/bundle:45:in `block in <top (required)>'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/exe/bundle:33:in `<top (required)>'
Bundler::InstallError: sass-embedded-1.60.0-x86_64-linux requires rubygems version >= 3.3.22, which is incompatible with the current version, 3.3.20
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/installer.rb:237:in `block in ensure_specs_are_compatible!'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/spec_set.rb:155:in `each'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/installer.rb:231:in `ensure_specs_are_compatible!'
  /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.4/lib/bundler/installer.rb:83:in `block in run'
I, [2023-04-06T09:50:56.916061 #1]  INFO -- : Running `bundle install --deployment --jobs 4 --retry 3 --verbose --without "test" "development"` with bundler 2.4.4
Frozen, using resolution from the lockfile
The definition is missing dependencies, failed to resolve & materialize locally (https://github.com/rails/sprockets (at 3.x@f4d3dae) is not yet checked out. Run `bundle install` first.)
2023-04-06 09:50:56.935 UTC [47] LOG:  shutting down
2023-04-06 09:50:56.970 UTC [43] LOG:  database system is shut down
104:M 06 Apr 2023 09:50:57.012 # User requested shutdown...
104:M 06 Apr 2023 09:50:57.012 * Saving the final RDB snapshot before exiting.
104:M 06 Apr 2023 09:50:57.036 * DB saved on disk
104:M 06 Apr 2023 09:50:57.036 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development' failed with return #<Process::Status: pid 367 exit 5>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'"]}
bootstrap failed with exit code 5
82f1cada0a0c138a0834f1682f3475590d0e28f179b243c4f0d54ae7043515bb
Somehow you have ruby 2.7.0 where I have ruby 3.2.0. Perhaps you could show your complete log - something has failed to be updated. The usual sequence is
cd /var/discourse
git pull
./launcher rebuild app
(although in your case, not app, but polyf)
In a nearby thread:
I run Debian [stable] (this is currently version 11, codenamed bullseye), for which the standard ruby package is version 2.7.0: I Challenge Thee
I’m a little surprised that git pull should be needed, considering that ./launcher already does that on rebuild:
However, I’m trying with a previous git pull now, which did get some mods, so I’m not sure I understand why the launcher did get those… Ah well, I’ll see how it goes and will come back to you.
I think it’s the version of Ruby inside the Docker container which counts, and that really should be right if the image was updated as it should have been. If you’re running something different from tests-passed then your image might be older, in which case the problem might be an incompatibility with a plugin which is too new. In that case, commenting out your plugins can narrow down which one is incompatible with your intentionally-old Discourse.
Maybe you are somehow on a dirty git state or in the old master branch?
With the ‘git pull’, the rebuild worked like charm.
@Falco, I was indeed in the old master branch. Now I’m in the new main branch… I can’t really say where that happened, it’s quite possible that a repeat run of launcher did it under the hood (I do see some code in there that does the switch if you happen to be in master).
Ah well, I’ll call this upgrade “magic” and not care beyond that, 'cause now, my discourse instance is happily up and running.
Thanks for the (moral if nothing else) support, guys!
A data point, BTW, is that I upgraded from version 2.9.0.beta9. Maybe that makes a difference…
I think this tells us what the git pull is about - it updates the launcher itself, before you run it. I didn’t know that.
@JammyDodger, thanks. I hadn’t discovered the “Solution” button yet.
[takes note]
