أهلاً،
منذ فترة لم نتمكن من ترقية نسختنا، فشلت إعادة البناء. تشغيل Discourse 2.8.9 في Docker. حاولت الترقية إلى 2.8.10 و 2.8.13 الآن.
./launcher rebuild app
I, [2022-12-01T12:10:27.197669 #1] INFO -- : cd /var/www/discourse & su discourse -c 'bundle exec rake plugin:pull_compatible_all'
bundler: failed to load command: rake (/var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake)
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/runtime.rb:308:in `check_for_activated_spec!': You have already activated uri 0.10.0, but your Gemfile requires uri 0.11.0. Since uri is a default gem, you can either remove your dependency on it or try updating to a newer version of bundler that supports uri as a default gem. (Gem::LoadError)
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/runtime.rb:25:in `block in setup'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/spec_set.rb:155:in `each'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/runtime.rb:24:in `map'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/runtime.rb:24:in `setup'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler.rb:162:in `setup'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/setup.rb:20:in `block in <top (required)>'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/ui/shell.rb:136:in `with_level'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/ui/shell.rb:88:in `silence'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/setup.rb:20:in `<top (required)>'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/cli/exec.rb:56:in `require_relative'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/cli/exec.rb:56:in `kernel_load'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/cli/exec.rb:23:in `run'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/cli.rb:486:in `exec'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/cli.rb:31:in `dispatch'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/cli.rb:25:in `start'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/exe/bundle:48:in `block in <top (required)>'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/lib/bundler/friendly_errors.rb:120:in `with_friendly_errors'
from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.22/exe/bundle:36:in `<top (required)>'
from /usr/local/bin/bundle:23:in `load'
from /usr/local/bin/bundle:23:in `<main>'
I, [2022-12-01T12:10:27.537797 #1] INFO -- :
I, [2022-12-01T12:10:27.538882 #1] INFO -- : cd /var/www/discourse & su discourse -c 'bundle exec rake db:migrate'
I, [2022-12-01T12:10:27.859901 #1] INFO -- :
I, [2022-12-01T12:10:27.861085 #1] INFO -- : Terminating async processes
I, [2022-12-01T12:10:27.861874 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 31
31:signal-handler (1669896627) Received SIGTERM scheduling shutdown...
31:M 01 Dec 2022 12:10:27.961 # User requested shutdown...
31:M 01 Dec 2022 12:10:27.963 * Saving the final RDB snapshot before exiting.
31:M 01 Dec 2022 12:10:28.025 * DB saved on disk
31:M 01 Dec 2022 12:10:28.027 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse & su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 4804 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
fde0a026f0cd2470f6fa579009db125a783db4115eab6d151389446042e22119
الترقيات قبل 2.8.10 لم تكن مشكلة. بعض المعلومات الإضافية هنا:
النظام:
Debian 11 Bullseye
8GB Ram
مساحة قرص حرة كافية
Postgres مثبت عبر مستودع PGDG، لا يعمل في حاوية.
الإضافات: فقط docker_manager و styleguide المثبتة مسبقًا
المكونات: Custom Header Links
app.yml
templates:
version: stable
تم استخدام القالب standalone.yml لـ app.yml
