Rebuild failed: ERR_PNPM_RECURSIVE_EXEC_FIRST_FAIL
I did rebuilding (2-container) just few minutes ago and I got this:
Environment: production
The setting 'staticAddonTrees' will default to true in the next version of Embroider and can't be turned off. To prepare for this y
ou should set 'staticAddonTrees: true' in your Embroider config.
The setting 'staticAddonTestSupportTrees' will default to true in the next version of Embroider and can't be turned off. To prepare
 for this you should set 'staticAddonTestSupportTrees: true' in your Embroider config.
building...
undefined
 ERR_PNPM_RECURSIVE_EXEC_FIRST_FAIL  Command was killed with SIGKILL (Forced termination): ember build -prod
What’s next?
6 posts were merged into an existing topic: Rebuild fails with exit 1: ERR_PNPM_RECURSIVE_EXEC_FIRST_FAIL
