הבנייה נכשלת מכיוון שעדיין על ענף `master`. תקן עם `git checkout main`
סיכום מבוסס בינה מלאכותית
The discussion revolves around a rebuild failure due to an issue with the master branch. pfaffman initially suspects a missing yarn as the cause, but after further investigation, they discover that the host is still on master instead of main. Falco suggests checking the base image version, but pfaffman resolves the issue by running git checkout main. This solution implies that hosts still on master may need to be updated to main to resolve similar issues.
I guess this missing yarn is the issue? I don’t what what could be causing it or anything else that might be an explanation…
discourse-checklist is already at latest compatible version
discourse-spoiler-alert is already at latest compatible version
discourse-affiliate is already at latest compatible version
I, [2022-02-15T18:02:48.675851 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
I, [2022-02-15T18:02:55.018972 #1]  INFO -- :
I, [2022-02-15T18:02:55.019167 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
sh: 1: yarn: not found
I, [2022-02-15T18:03:00.609631 #1]  INFO -- : Checking 'Easy Footer (TH)' for 'default'... up to date
Checking 'discourse-user-field-prompt' for 'default'... up to date
Checking 'Rotate Global Banner(JP)' for 'default'...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 5437 exit 127>
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
d6ac4e7c27174dd04269576be15628207fe7d8d19f99c6ea524836f8ee43b895
Our base image ships with yarn for a while. What is the base image version you are running?
I thought I was going crazy.
The issue was that this host was still on master; git checkout main has solved the problem.
I guess I should be doing a git checkout main on all hosts two-container hosts where the procedure is to bootstrap/destroy/start rather than rebuild in case they’re old enough to need it.
